MPI finale ppt presentaion
Douglas Johnson
djohnson at osc.edu
Fri May 19 11:40:33 CDT 2000
If you downloaded the finale.ppt file from OSC before 12:40pm, please
download the file again so that your copy includes Sandie Knappes slide.
On Fri, 19 May 2000, George Estes wrote:
> Please ignore the previous message reference powerpoint slides. Sandie
> Kappes from NCSA only has one slide, and it is included in the finale.ppt
> set. So we do not even need to run master from NCSA. Sorry for the
> confusion.
> George
> <italic>
> The powerpoint slides from NCSA are located at
> www.ncsa.uiuc.edu/MEDIA/agppt/finale2.ppt
> and they will be served from agaudio.ncsa.uiuc.edu.
> </italic>
> At 11:39 AM 5/19/00 -0400, you wrote:
> >Greetings,
> >For the sake of simplicity and the ability to use the AG most
> >efficiently - there is no reason to switch the DPPT server during this
> >or any in progress meeting. This creates more places where trouble
> can
> >occur.
> >I suggest that we use the OSC server for the duration of the meeting.
> >This does not mean that NCSA should not or can not run as the dppt
> >master during their presentation of their slides.
> > --Russ
> >> George
> >> At 11:21 AM 5/19/00 -0400, Douglas Johnson wrote:
> >> >Hi,
> >> > For the sites that are participating in the MPI finale today,
> the
> >> >power point slides are located at www.osc.edu/~djohnson/finale.ppt.
> The
> >> >dppt server will be agdisplay.grid.osc.edu. See you at 3:30pm edt.
Doug Johnson
Systems Developer/Engineer
The Ohio Supercomputer Center
djohnson at osc.edu
