Emergency fix for v0.53 beacon viewer
Kai Chen
kchen at ncsa.uiuc.edu
Thu Mar 23 13:46:39 CST 2000
Alternatively, you can also download the corrected compact viewer at
http://dast.nlanr.net/projects/beacon/viewer-compact-03232000.tar.gz
The packet size is now configurable via the command line (see the start
scripts for details). Current setting in the script is 40960 bytes.
On Thu, 23 Mar 2000, Bill Nickless wrote:
> We appear to have hit another hardcoded limit in the beacon viewer code,
> even the latest version 0.53. To get around this limit for now, change
> line 21 of BeaconViewer.java from
> final static int maxMonitorPacketSize = 20480;
> to
> final static int maxMonitorPacketSize = 40960;
> You will need to recompile the java code and restart. I use the command
> c:\jdk1.2.2\bin\javac *.java
> to accomplish the recompilation.
> Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
> PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
Kai Chen Research Programmer
217-265-4078 NLANR Application Support
kchen at nlanr.net NCSA - U of Illinois at Urbana-Champaign
