Video Capture box stability probs
Robert Olson
olson at mcs.anl.gov
Fri Jun 9 10:37:10 CDT 2000
Try running dmesg and look for a verison message from bttv. It should look
something like this:
Linux video capture interface: v0.01 ALPHA
i2c: initialized
bttv0: Brooktree Bt878 (rev 2) bus: 0, devfn: 120, irq: 15, memory: 0xfd5fe000.
bttv1: Brooktree Bt878 (rev 2) bus: 0, devfn: 128, irq: 11, memory: 0xfd5fc000.
bttv: 2 Bt8xx card(s) found.
bttv0: model: BT878(Hauppauge new (bt878))
i2c: bus registered: bt848-0
bttv1: Hauppauge eeprom: tuner=Philips FM1236 (2)
bttv1: model: BT878(Hauppauge new (bt878))
i2c: bus registered: bt848-1
The v0.01 ALPHA is a signal that it isn't the RedHat default kernel
drivers. THey show up as something like:
Linux video capture interface: v1.00
bttv0: Brooktree Bt878 (rev 2) bus: 0, devfn: 136, irq: 9, memory: 0xf4001000.
PCI: Enabling bus mastering for device 00:88
bttv: 1 Bt8xx card(s) found.
bttv0: NO fader chip: TEA6300
bttv0: model: BT878(Hauppauge new)
--bob
At 10:16 AM 6/9/2000 -0500, Allan Bautista wrote:
>Im having some problems with my video capture box.
>Spec:
>dual p3 600's w 256mb PC100 mem
>4 Hauppage wintv cards
>3com 10/100 nic
>Running RedHat 6.1, configured with Bob's script
>Problem:
>Im constantly dropping transmissions from this box, all 4 feeds work fine
>for about 3-4 min after theyve been started. From there they will start
>to drop out one by one till they are all gone.
>Ive tried running 3, 2 then one feed to see how long they will last.
>the longest transmission Ive had sofar is about 1 hour with one feed.
>Now, during the Globus tutorials I was having the same problem, so I
>manually started up vic sessions in the proper rooms and had better
>stability with that. Differences were quality settings, fps settings, and
>rate settings. I usually had an fps of 30, q of 10, and set the threshold
>rate at 500k.
>Ive already reinstalled all the software so my vid machine is clean, but
>exhibiting the same behavior as before. Prior to installing the VV stuff,
>"when all the feeds were manually typed in", the machine was stable, it
>would transmit for days/weeks with no problems. So Im not sure where to
>point, hardware or software. I think the hardware is fine, and since Ive
>reinstalled clean I "think" the software setup is ok.
>The only thing close to an error message I get comes from the window I
>spawned vrm-viewer from
> subprocess died: ag.VicVideo at 80de1a8
> delete returns false
>Now Im just plain stumped.
>any suggestions?
>Al @ ACCESS
>abautist at ncsa.uiuc.edu
