Event Server (a bit more info)
Patrick Toomey
toomey at rsch.comm.mot.com
Thu Jul 27 09:20:20 CDT 2000
Hey,
Thanks for the help. I had forgotten that I started up the event server weeks
ago when I was testing things out. I hadn't realized the process was still running
in the background. Upon killing the old process everything has been working
perfectly. Again, thanks for all your help.
Patrick Toomey
Motorola Labs
Robert Olson wrote:
> The didn't find nameservice isn't really an error, just an informational
> (and should probably go away). It's odd that the mediachannel already
> existed. Make sure maybe that you didn't start a second eventserv (check
> the process list).
> --bob
> At 04:31 PM 7/26/2000 -0500, Patrick Toomey wrote:
> >Hey,
> > I have gone through and done what I thought was correct, but I'm
> >still having the problem. I thought it might be useful to show you all
> >the output of each command.
> >First I start the event-listener.bat and it outputs the following:
> >C:\agapps\bin>c:\agapps\jre-1.1.8\bin\jre -nojit -cp
> >c:\agapps\ag-resource-mgr
> >ar;c:\agapps\java-getopt.jar;c:\agapps\ooc\lib\ob.jar;c:\agapps\ooc\lib\obnami
> >.jar;c:\agapps\ooc\lib\obevent.jar;c:\agapps\swing-1.1.1fcs\swingall.jar
> >ag.Ev
> >tServerMonitor
> >Create gui
> >Gui created
> >Monitor thread starting!
> >Didn't find name service: org.omg.CORBA.ORBPackage.InvalidName
> >getting objref
> >narrowing
> >Got factory
> >com.ooc.OBEventChannelFactory.StubForEventChannelFactory at 16273f
> >Creating channel mediaChannel
> >Hm, channel mediaChannel already exists
> >com.ooc.OBEventChannelFactory.ChannelAlreadyExists
> > at
> >com.ooc.OBEventChannelFactory.ChannelAlreadyExistsHelper.read(Chann
> >AlreadyExistsHelper.java:68)
> > at
> >com.ooc.OBEventChannelFactory.ChannelAlreadyExistsHelper.extract(Ch
> >nelAlreadyExistsHelper.java:35)
> > at
> >com.ooc.OBEventChannelFactory.StubForEventChannelFactory.create_cha
> >el(StubForEventChannelFactory.java:62)
> > at ag.initEventServer.createChannel(initEventServer.java:53)
> > at ag.initEventServer.<init>(initEventServer.java:34)
> > at
> >ag.EventServerMonitor.setupChannel(EventServerMonitor.java:236)
> > at ag.EventServerMonitor.run(EventServerMonitor.java:197)
> > at java.lang.Thread.run(Thread.java:466)
> >Then I start drm and get this:
> >c:\agapps\ag-resource-mgr.j
> >aming
> >ag.Disp
> >layResourceManager --event iioploc://localhost:10001/mediaChannel
> >Got event channel
> >org.omg.CosEventChannelAdmin.StubForEventChannel at 160db2
> >Then I start the arm-evenlistener and get:
> >Got event channel
> >org.omg.CosEventChannelAdmin.StubForEventChannel at 80db94a
> >name=Motorola_Labs
> >Lastly I start up arm-evenlistener and get:
> >Got event channel
> >I don't really know what the "didn't find name service" line in each of
> >these is trying to tell me. Any info you all can pass me would be much
> >appreciated. Thanks for all your help.
> >Patrick Toomey
> >Motorola Labs
