scan converters
Lisa C. Childers
childers at mcs.anl.gov
Tue Jul 4 18:06:38 CDT 2000
Michael,
Can you be more specific about the problems you are having with vnc?
Using vnc during the globus tutorial was intuitive and easy.
Lisa
On Tue, 4 Jul 2000, Michael Grobe wrote:
> hello:
> the various complexities of using VNC for screen-sharing demos
> got me to thinking about alternatives.
> has anyone tried using scan converters for these demos?
> that is, in more detail:
> use a scan converter to take the VGA signal from a laptop
> or workstation and convert it to composite video for the
> video capture card for normal broadcast over the grid.
> this would be MUCH simpler than the VNC approach (especially the
> bi-level VNC approach invented by eric). i suppose it would
> be considerably lower resolution, so it would be unusable for
> some demos or PPT slide sets.
> i have found a cheap scan converter...well, relatively cheap...
> $495 list price...i have a call in to see about an edu discount.
> for similar quality (VSC-75 or VSC-100) the Extron edu price
> appears to be about $1000.
> the product is the CORIOscan Select from tvone.com (www.tvone.com).
> (up to 1024x768, composite, s-video, and RGB output, ntsc and pal
> switchable, scan rates up to 100KHz, etc.)
> if nothing else this MIGHT make a reasonable backup tool for VNC
> and dPPT, if it isn't good enough for general use.
> :michael grobe
