interlacing discussion ...
Robert Olson
olson at mcs.anl.gov
Wed Jan 12 15:28:50 CST 2000
from video4linux list.
interesting thing; old sony digital camera with video output doesn't have
interlacing artifacts...
>Resent-Date: 12 Jan 2000 21:02:10 -0000
>Resent-Cc: recipient list not shown: ;
>MBOX-Line: From video4linux-list-request at redhat.com Wed Jan 12 16:02:09 2000
>X-Authentication-Warning: xyzzy.dsl.speakeasy.net: xyzzy owned process doing
>-bs
>Date: Wed, 12 Jan 2000 13:02:02 -0800 (PST)
>From: Trent Piepho <xyzzy at speakeasy.org>
>X-Sender: xyzzy at xyzzy.dsl.speakeasy.net
>To: video4linux-list at redhat.com
>Subject: Re: Matrox Meteor II driver project?
>In-Reply-To: <200001122042.PAA23848 at devserv.devel.redhat.com>
>Message-ID:
<Pine.LNX.4.04.10001121258001.27254-100000 at xyzzy.dsl.speakeasy.net>
>MIME-Version: 1.0
>Content-Type: TEXT/PLAIN; charset=US-ASCII
>Resent-Message-ID: <"ycfpf1.0.yp5.HlEVu"@lists.redhat.com>
>Resent-From: video4linux-list at redhat.com
>Reply-To: video4linux-list at redhat.com
>X-Mailing-List: <video4linux-list at redhat.com> archive/latest/901
>X-Loop: video4linux-list at redhat.com
>Precedence: list
>Resent-Sender: video4linux-list-request at redhat.com
>X-URL: http://www.redhat.com
>On Wed, 12 Jan 2000, Alan Cox wrote:
>> > NetWinder (www.netwinder.org) that has Philips SAA7111 shows exactly the
>> > same type of
>> > distortions (runs Linux) during capturing dynamic videos which leads
me to
>> > believe it's common
>> > problem for low-cost capture boards.
>> Your monitor displays at 60-100hz (hopefully 72+). The incoming TV signal
>> is 25fps and interlaced. You need to do extra bufffering and burn CPU time
>> and memory to do good delacing, or find a card that has big buffers.
>> This isnt a _capture_ artefact its a viewing artefact
>Sure it is. You can see interlacing artifacts just fine on still single
frame
>captures. Take a look at http://xyzzy.dsl.speakeasy.net/~xyzzy/test.jpg, you
>can see the interlacing artifacts perfectly on the scrolling stock ticker on
>the bottom of the screen.
> To unsubscribe: mail video4linux-list-request at redhat.com with
> "unsubscribe" as the Subject.
>Resent-Date: 12 Jan 2000 21:12:35 -0000
>MBOX-Line: From video4linux-list-request at redhat.com Wed Jan 12 16:12:34 2000
>Message-ID: <387CEE06.3E0FFEFC at osprey.viewcast.com>
>Date: Wed, 12 Jan 2000 16:11:34 -0500
>From: H Brett Bolen <brettb at osprey.viewcast.com>
>Reply-To: brettb at osprey.viewcast.com
>Organization: ViewCast.com
>X-Mailer: Mozilla 4.7 [en] (WinNT; I)
>X-Accept-Language: en
>MIME-Version: 1.0
>References:
>Content-Type: text/plain; charset=iso-8859-1
>Content-Transfer-Encoding: 8bit
>Resent-Message-ID: <"xh2pG3.0.yA7.2vEVu"@lists.redhat.com>
>X-Mailing-List: <video4linux-list at redhat.com> archive/latest/903
>Precedence: list
>Broadcast sources are interlaced. When you view a single
>frame on a video monitor you are really seeing two frames
>which are separated in time by 15 or 20 milliseconds.
>If an edge moves a noticeable amount then you will have the zigzag
>effect. This has nothing to do with the capture, it is in the
>source.
>One way to get rid of the effect is to capture 320x240 instead
>of 640x480. another is to capture 640x240 and to 'double'
>each of the 240 lines so that there are 480 lines.
>The problem is not with capture, but with the source. This
>is why there is so much discussion about the quality of
>720p vs 1020i on the HDTV boards ( interlaced vs progressive
>scan ).
>i is bad...... p is good.....
>b²
exactly the
>> > > same type of
>me to
>> > > believe it's common
time
>frame
ticker on
