Multicast status
Tom Coffin
tcoffin at ncsa.uiuc.edu
Wed Feb 9 12:04:26 CST 2000
Tony,
I also saw your joking comments on the mud in reference to the last
paragraph...
I find some of your comments unprofessional, unconstructive, and way out of
line.
Especially being labelled as a rouge site and your dismissal of my
inteligence
in being able to comprehend the insurmountable technical difficulties of
enabling
a multicast bridge.
re ACCESS agnode:
I have supported this project 100+%, sacrificed in ways you could not imagine,
and have developed the ACCESS AG node as the high-end producer of content for
the Access Grid project. My feelings are very hurt by your unsolicited
condemnation
of me and my work to this ag-tech list. I do not believe I deserve it.
If you have problems with me on a personal or professional level, please
address
them to me directly.
re bridges as a backup:
From, a production perspective (one which should be addressed because the
production values up to this point have been weak at best). I was simply
stating that
bridge technologies should always be kept in hand as a possible backup
solution.
re my interest in multicast bridges:
I have no interest in creating a bridge at ACCESS for the Access Grid
project.
I am however, interested in their technology (irregardless of your low
opinion
of my capabilities to understand them) and again ask:
Where can I learn more information on setting up a multicast bridge?
______________________________________________
At 10:20 AM 2/9/00 -0600, Tony Rimovsky wrote:
>Tom, please don't pursue your own bridge. I am fairly certain that you
will
>run into insurmountable technical difficulty getting one to work, and I
>can't devote the resources to helping you do troubleshoot. Setting up a
>bridge at access-dc will increase my group's workload and be in direct
>contradiction to what the access-grid developers are trying to accomplish.
>There is also a good possibility that the current pipe to access-dc
couldn't
>handle the load..
>Currently, the bridge is not simply a backup. It discourages some of the
>core goals of the access-grid model by allowing remote sites to be lazy
>about dealing with multicast. After a year of using the access-grid,
there
>are still active sites no closer to native multicast because, in part
>because the bridge exists. Furthermore, the bridge confuses
>troubleshooting, further complicating the multicast picture when something
>does go wrong.
>There is no reason for this community to allow something as significant
as a
>Chautauqua happen again without having put the advance effort in to make
>sure that key sites are enabled. Smaller impromptu events are taking a
risk
>in relying on access-grid technology at this stage. All it takes is
one key
>person to be unavailable for things to break down (and that is true
even if
>you don't use multicast.)
>Bill has outlined alternative solutions which encourage the proper
>direction. He has offered to help sites. I extend the same offer.
>Particularly with the NSF, it is significant that we we get proper
multicast
>working, either natively or using specific hardware at the remote sites.
>And, in point of fact, not every major event has required using the
bridge.
>The recent Illinois Governor's visit is a positive example, and I
believe I
>heard Larry describe it as the best access-grid demo yet. As time passes,
>the technology has improved. Troubleshooting multicast problems is almost
>routine now, with the bigest delays being caused by unavailable staff, not
>mysterious technology failures.
>Final point: if the community decides that a backup mechanism is necessary
>as a backup, then ANL should organize the implimentation, _not_ a rouge
site
>that decides they know better. Make your case to ANL people and the
rest of
>the community. If people generally think you are making sense about
>backups, then I am sure a bridge of some sort will remain. (They may even
>decided it should be hosted at ACCESS!) An open invitation was part of
the
>propsal sent to the list on 1/27 and there hadn't been any negative
feedback
>(other than some concern about increased $$) in response until now. The
>point about backups probably needs to be discussed. Bob/Bill/Lisa, do you
>have anything in mind with respect to a safety net?
>On Wed, 09 Feb 2000, Tom Coffin wrote:
>> True, the mission of the Access Grid is to exist in a multicast
>> environment.
>> However, for large scale production events like a Chautauqua 'bridges'
>> should still be in place and accessible as 'backup'. (for example every
>> large event [sc99, chautauquas] to date has required ACCESS to switch
>> to
>> a bridge to be seen or heard. We employ telephone backups why not
>> network backups?
>> regarding cise-nsf.gov, they currently do not have multicast enabled.
>> I believe they want a permanent presence on the Access Grid project.
>> I will touch base with the folks at NSF to see what's going on with
>> their becoming multicast enabled.
>> At 09:21 AM 2/9/00 -0600, Robert Olson wrote:
>> > In the effort to rid ourselves of multicast bridges, I thought it'd
>> > be good to get an update on status from folks. The following groups
>> > are in the bridge configs:
>> > VA Linux Corporate folks, no working multicast
>> > Utah I seem to remember you guys having working
>> > multicast
>> > Boston Did you get your one-way multicast fixed?
>> > UNM This is a work in progress, right?
>> > MPHCC Also a work in progress if I recall correctly
>> > Kentucky Also a work in progress if I recall correctly
>> > cise-nsf.gov Tom -- this was a one-time thing, right?
>> > EVL/UIC As I recall, this requires a longer-term fix. Status?
>> > UIUC CS dept onetime for Dan Reed I think. Anyone know status
>> > of multicast there?
>> > Nestor's lab Bill, I think this is working multicast now, right?
>> > microsocopy.com Nestor's home. hm.
>> > msu.ru Onetime demo, I think
>> > thanks,
>> > --bob
>> ___________________________________________________________
>> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
> | Tony Rimovsky, Manager -- Network Development Phone: +1 217
244-4728 |
> | National Center for Supercomputing Applications FAX: +1 217
244-1987 |
> | 605 E Springfield, Champaign IL, 61820 tony at ncsa.uiuc.edu
