[AG-TECH] Multicast to Alaska
Bob Huebert
huebert at arsc.edu
Thu Dec 14 20:04:00 CST 2000
You are correct in seeing a path to/from ARSC/ANL. Problem is, as I'm
told, is that this is strictly a unicast route - for now. There is a
plan to implement multicast over this route sometime shortly into the
new year.
Also, the 137.229 domain you traced to was swapped to 199.165 for
ARSC this past August.
Thanks
Bob
At 3:21 PM -0600 12/14/00, Bill Nickless wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Are you sure that DREN is your only link?
>I'm getting your route this way:
>Kiwi#show ip bgp 137.229.0.0
>BGP routing table entry for 137.229.0.0/16, version 5183141
>Paths: (8 available, best #3)
> Advertised to peer-groups:
> embgp-mc-transit imbgp-mesh
> 145 11537 101 7774
> 192.5.170.130 from 192.5.170.130 (204.147.128.158)
> Origin IGP, metric 900, localpref 10000, valid, external
> Community: 145:999 11537:900 11537:950
> 145 11537 101 7774, (received-only)
> Origin IGP, localpref 100, valid, external
> 11537 101 7774
> 192.5.170.170 from 192.5.170.170 (198.32.8.252)
> Origin IGP, metric 800, localpref 10000, valid, external, best
> Community: 11537:900 11537:950
> 293 11537 101 7774
> 198.124.254.165 from 198.124.254.165 (134.55.29.97)
> Origin IGP, metric 1100, localpref 10000, valid, external
> 293 11537 101 7774, (received-only)
> 2914 101 7774
> 192.5.170.166 from 192.5.170.166 (129.250.0.57)
> Origin IGP, metric 4000, localpref 10000, valid, external
> 2914 101 7774, (received-only)
> Origin IGP, metric 21, localpref 100, valid, external
>...which seems to imply that you're directly connected to the University of
>Washington (ASN 101) in Seattle, who connects to Abilene. University of
>Washington appears to be IP multicast connected. Is that an option for you?
>At 11:33 AM 12/14/2000 -0900, Bob Huebert wrote:
>>Hi All,
>> Our node is up and functioning, but unable to join the Abilene
>> multicast groups. Seems we have a tunnel to a DREN site which doesn't
>> provide the path that we need to join the Access Grid with our node. I
>> understand that there are efforts underway to enable multicast on the
>> DREN, but until that time I'd like to see if we could find a tunnel which
>> would lead to Abilene. Is there another AG site which would consider
>> providing a tunnel to Alaska?
>>Thanks
>>Bob
>>_______________________________________________________________________
>>Bob Huebert email: huebert at arsc.edu
>>HPC Visualization Systems Analyst voice: (907) 474-5751
>>Arctic Region Supercomputing Center FAX: (907) 474-5494
>>University of Alaska Fairbanks WWW: http://www.arsc.edu/
>Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
>PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
>-----BEGIN PGP SIGNATURE-----
>Version: PGPfreeware 6.5.8 for non-commercial use <http://www.pgp.com>
>iQCVAwUBOjk5zawgm7ipJDXBAQHFKAP6A2j9hlNlLCLLVE8t+bvKTPHEUTOlgoFZ
>BEMP2knNxuyFLG08EzkHUbBC9nwzLQmp/rOtuFPOPbDxJRpZbB/UoDRItYCzk0bR
>d18seJBGLXFCXBbSYrZq1W0S5eBiIzXzDK0Jklt1qxwtss7GeGFFSUm2Oxqgzq9O
>BSiaRdxU0+4=
>=vCp+
>-----END PGP SIGNATURE-----
