RealMedia
Robert Olson
olson at mcs.anl.gov
Tue Aug 29 09:57:30 CDT 2000
The configuration depends somewhat on what you are planning on
transmitting. If you are just sending local talks, you can split the video
from the presenter camera to go to both the video capture box and to your
realmedia server. If you are going to do multicamera local stuff, you'll
need a switcher unless you get a capture card with multiple inpts and an
internal switcher.
For the audio, you should connect a gentner output to the RM server. Then
you can do things like route network audio to the RM server as well as
local microphone audio.
(I'm assuming that the RM stuff would be served off its own machine..)
--bob
At 10:36 AM 8/29/2000 -0400, Jennifer Teig von Hoffman wrote:
>We're thinking about setting up RealMedia capability on the BU AG node
>(ie, setting up a RealMedia server which could take the same audio and
>video feeds we're feeding into vic and rat and sending them out over
>RealMedia as well). I've had a bit of advice from Al Bautista, who
>was involved in such a set-up at ACCESS-DC, and realize that some sort of
>video-switching device may be necessary.
>Does anybody else have experience with setting up RealMedia for an AG
>node? Any/all advice would be very much appreciated.
>- Jennifer
