Fwd: 4/19 Multicast Debugging -- Bill Fenner, AT&T Labs - Research
Robert Olson
olson at mcs.anl.gov
Thu Apr 13 13:05:17 CDT 2000
Interesting..
>X-Sender: florissa at plateau.cs.berkeley.edu
>X-Mailer: QUALCOMM Windows Eudora Pro Version 3.0.3 (32)
>Date: Thu, 13 Apr 2000 10:30:00 -0700
>To: (Recipient list suppressed)
>From: Florissa Colina <florissa at bmrc.berkeley.edu>
>Subject: 4/19 Multicast Debugging -- Bill Fenner, AT&T Labs - Research
>X-Mailing-List: <rem-conf at es.net>
>X-Loop: rem-conf at es.net
>Berkeley Multimedia, Graphics and Interfaces Seminar
>Multicast Debugging
>Wednesday April 19, 2000
>1:10-2:30 p.m. PDT
>Fujitsu Seminar Room (405 Soda Hall)
>Bill Fenner
>Network topologies can be complex, and the application and control traffic
>can create a 'chemistry' of loads and flows that leads to unanticipated
>network congestion and application failure. This session will provide
>network engineers valuable information on debugging congestion,
>misconfiguration, application failure to help keep networks and content
>delivery reliable.
>The seminar is broadcast live on the Internet Mbone and as a Real Networks
>G2 broadcast.
>You can connect to the live RealNetworks broadcast at:
>http://media2.bmrc.berkeley.edu/bibs/schedule.cfm
>You'll see a link to cs298-5/real networks/live programs.
>You can also directly put in this url into the Real Player:
>rtsp://media2.bmrc.berkeley.edu/encoder/cs298-5.rm
>To do so you will need to have the "Real Player G2" installed, which is
>available from:
>http://www.real.com/products/player/downloadrealplayer.html
>To tune into the Internet MBone broadcast, look for the announcement in
>your MBone session directory program ('sdr'). If you are not receiving the
>announcement you may be able to receive the session by manually configuring
>the client programs ('vic', and 'vat') with the session addresses:
>low bit rate
> video: 233.0.25.1/22334
> audio: 233.0.25.2/22446
>medium bit rate
> video: 233.0.25.129/22334
>You can get further information about this seminar, and access to replays
>of previous seminars at the MIG Seminar web page:
>http://bmrc.berkeley.edu/298/index.html
>Sponsored by the Berkeley Multimedia Research Center
