Rat & Control-Z (fwd)
    Bob Olson
    olson at mcs.anl.gov
    Fri Apr  7 11:03:11 CDT 2000
FYI... on the suspending rat problem.
For now the answer is probably "don't do that" (don't suspend rat, just
put it in the background at start).
--bob
---------- Forwarded message ----------
Date: Fri, 07 Apr 2000 16:56:13 +0100
To: Robert Olson <olson at mcs.anl.gov>
Cc: rat-trap at cs.ucl.ac.uk
Subject: Re: Rat & Control-Z
<4.2.0.58.20000407081019.01732f00 at localhost>Robert Olson writes:
> We've been seeing rat crashes on linux & SGI after a message 'can't send
> mbus message' that seem to be correlated with suspending rat with control Z
> and then resuming it. Have you come across this?
Yes, there are timers on the mbus messages that are marked as
reliable, and retransmits get triggered if there is no ack (because
the app is stopped).  For the time being the code aborts if a reliable
message is not received, but it could just mark that application as
not present or the controller could fork itself off to get around
this.
- Orion.
