Multicast Reachability Monitor
Linda Winkler
winkler at mcs.anl.gov
Tue Oct 26 09:12:23 CDT 1999
It is in the Cisco IOS.
lw
At 08:58 AM 10/26/99 -0500, Robert Olson wrote:
>Aha. This looks like what we've been wanting. I don't see any
>implementations, unfortunately.
>--bob
>http://www.ietf.org/internet-drafts/draft-ietf-mboned-mrm-00.txt
>MBone Deployment Working Group Kevin Almeroth (ed)
>Internet Engineering Task Force UCSB
>Internet Draft Liming Wei
>October 1999 Siara Systems, Inc.
>Expires: April 1999 Dino Farinacci
> Cisco
> Multicast Reachability Monitor (MRM)
> <draft-ietf-mboned-mrm-00.txt>
>Status of this Memo
> This document is an Internet-Draft and is in full conformance
> with all provisions of Section 10 of RFC2026.
> Internet-Drafts are working documents of the Internet Engineering
> Task Force (IETF), its areas, and its working groups. Note that
> other groups may also distribute working documents as
> Internet-Drafts.
> Internet-Drafts are draft documents valid for a maximum of six
> months and may be updated, replaced, or obsoleted by other
> documents at any time. It is inappropriate to use Internet-
> Drafts as reference material or to cite them other than as
> "work in progress."
> The list of current Internet-Drafts can be accessed at
> http://www.ietf.org/ietf/1id-abstracts.txt
> The list of Internet-Draft Shadow Directories can be accessed at
> http://www.ietf.org/shadow.html.
>Abstract
> MRM facilitates automated fault detection and fault isolation in a
> large multicast routing infrastructure. It is designed to alarm a
> network administrator of multicast reachability problems in close
> to real-time.
> There are two basic types of components in MRM, MRM manager and MRM
> testers. This document specifies the protocol with which the two MRM
> components communicate, the types of operations the testers perform,
> and information an MRM manager can obtain.
>Almeroth, Wei, Farinacci [Page 1]
>Internet Draft <draft-ietf-mboned-mrm-01.txt> October 1999
>Table of Contents
> Abstract . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
>1. Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
> 1.1 Partitioning Network Monitoring Tasks . . . . . . . . . . . . 3
>2. Functions of the MRM Mechanism . . . . . . . . . . . . . . . . . . 4
> 2.1 Fault Detection . . . . . . . . . . . . . . . . . . . . . . . 4
> 2.2 Fault Isolation . . . . . . . . . . . . . . . . . . . . . . . 5
> 2.3 The Protocol . . . . . . . . . . . . . . . . . . . . . . . . . 5
> 2.3.1 MRM Manager Requests . . . . . . . . . . . . . . . . . . 6
> 2.3.1.1 MRM Manager Beacon Message . . . . . . . . . . . . . 7
> 2.3.1.2 Test Sender Requests (TSRs) . . . . . . . . . . . . 7
> 2.3.1.3 Test Receiver Requests (TRRs) . . . . . . . . . . . 8
> 2.3.2 Status Reports . . . . . . . . . . . . . . . . . . . . . 10
>3. Use of MRM Well Known Addresses and Ports . . . . . . . . . . . . 11
>4. Message Formats . . . . . . . . . . . . . . . . . . . . . . . . . 11
> 4.1 MRM Message Header . . . . . . . . . . . . . . . . . . . . . . 12
> 4.2 MRM Manager Beacon Message . . . . . . . . . . . . . . . . . . 13
> 4.3 Test Sender Request (TSR) . . . . . . . . . . . . . . . . . . 13
> 4.4 Test Receiver Requests (TRR) . . . . . . . . . . . . . . . . . 14
> 4.5 Status Report to the MRM Manager . . . . . . . . . . . . . . . 16
> 4.6 MRM Test Packet . . . . . . . . . . . . . . . . . . . . . . . 17
> 4.7 MRM Request-Ack Messages . . . . . . . . . . . . . . . . . . . 17
>5. Authenticating MRM Messages . . . . . . . . . . . . . . . . . . . 17
> 5.1 Generating Authenticated Messages . . . . . . . . . . . . . . 18
> 5.2 Receiving Authenticated Messages . . . . . . . . . . . . . . . 18
> 5.3 Key Management . . . . . . . . . . . . . . . . . . . . . . . . 18
>6. Security Considerations . . . . . . . . . . . . . . . . . . . . . 19
>7. Different Approaches to Implement MRM . . . . . . . . . . . . . . 19
>8. Example of an MRM Setup . . . . . . . . . . . . . . . . . . . . . 19
>9. Acknowledgment . . . . . . . . . . . . . . . . . . . . . . . . . . 21
>10. Authors addresses . . . . . . . . . . . . . . . . . . . . . . . . 21
>11. References . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
>Appendix A - Change History . . . . . . . . . . . . . . . . . . . . . 22
>Almeroth, Wei, Farinacci [Page 2]
>1. Introduction
> The Multicast Reachability Monitor (MRM) is a network fault detection
> and isolation mechanism for administering a multicast routing
> infrastructure. It is proposed in response to requests from network
> managers and users who need more systematic ways to get up-to-date
> multicast reachability status. For these purposes, existing tools are
> inefficient and inconvenient to use across large numbers of systems.
> The companion document [mrm-use] contains additional information on
> justification and usage guidelines for MRM.
> The design goals for MRM include:
> (1) Close to real-time detection and alarm of network problems,
> independent of user input;
> (2) Good coverage over the network, both in terms of the number of
> systems to be monitored, and the types of diagnostics to be
> performed;
> (3) Good extensibility and relative independence of other specific
> diagnostic tools and protocols (we borrow packet formats from
> RTPv2, but almost nothing else from the RTP protocol). This makes
> it easy to incorporate newer diagnostic tools as they become
> available.
> Functionally, the task of monitoring a multicast domain can be
> divided into two subtasks:
> (1) Fault detection
> (2) Fault isolation
> In the fault detection phase, the participating MRM systems do not
> need much detail about the nature of the fault. The mechanism can
> be very simple and brute force. Data packets can be originated
> from designated locations in the network and reception conditions
> monitored from other locations.
> In the fault isolation phase, depending on the types of fault
> identified, the MRM manager can use proper tools to isolate the
> fault and hopefully pin-point the location or reasons of the fault.
> The rest of this document is organized as follows, Section 2
> describes the MRM framework and details of the MRM protocol; Section
> 3 describes the usage of the well known MRM addresses and ports;
> Section 4 specifies packet formats; Sections 5 discusses the MRM
> authentication mechanisms; Section 6 discusses a few security issues;
> and Section 8 gives an example of MRM setup.
>Almeroth, Wei, Farinacci [Page 3]
> An MRM based fault monitoring system consists of two types of
> components: (1) an MRM manager that configures tests, collects and
> presents fault information, and (2) MRM testers that source or sink
> test traffic. These components collaborate to accomplish the two
> functions of MRM: fault detection and fault isolation.
> The MRM testers can be any routing devices or trusted end hosts.
> They provide statistics about received data packets, to be used to
> derive the network reachability status. These data packets can be
> sourced by a router acting as an MRM tester, in response to a request
> from the MRM manager. A system originating MRM data packets for
> testing purposes is also called a Test Source (TS). A configured
> set of MRM testers receiving the test traffic, and collecting
> receiver statistics are also called Test Receivers (TRs).
> An MRM manager initiates configuration requests to the MRM testers
> and assigns the roles of TSs and TRs. The MRM manager informs the TSs
> and TRs the types of monitoring or diagnostic tests to run. The MRM
> manager also specifies the type of reports the TRs should send.
> To guard against attacks on the MRM systems, IPsec Authentication
> Header (AH) [AH] is used with HMAC-MD5 transformation as the standard
> authentication algorithm. Authentication should always be enabled,
> especially when MRM is used to monitor production services.
> Note that this document only specifies the types of information an MRM
> manager can obtain, and the protocol used to acquire such
> information. How an MRM manager processes or presents the diagnostic
> information is an implementation issue. An MRM manager can be as
> simple as a command line wrapper of requests with simple display
> functions, it can also be more sophisticated and incorporated as part
> of a operational network monitoring tool in daily use by a network
> operation center (NOC).
>2.1 Fault Detection
> Multicast routing can behave abnormally in different ways. The
> following are a few common types of faults:
> (1) Topological disconnectivity
> The network topology for multicast routing is disconnected. For
> example when a route for a subset of the networks are not in the
> topology table.
>Almeroth, Wei, Farinacci [Page 4]
> (2) Black holes in forwarding path
> No multicast packets can get through to certain receivers, even
> though the network topology is perhaps intact. A possible cause
> could be disabled multicast forwarding. Another possibility is
> pruning errors,n e.g. due to inconsistent actions and timer
> values on a multi-access LAN.
> (3) Excessive/persistent Losses
> Packets flow, but with excessive losses over extended period of
> time. The possible causes include heavy congestion, line errors
> or misuse of forwarding modes, etc.
> (4) Excessive duplicates
> Packets arrive at the receivers, but with large numbers of
> duplicates.
> (5) Others
> Other types of fault that can be detected, e.g. non-pruners
> as a failure mode. A non-pruning neighbor can be a sink for all
> multicast traffic at all times, even if no receivers exist behind
> that neighbor. This is "outlawed" by the "MBONE-community" [jhawk].
> Detecting the existence of such system in an inter-domain scenario,
> however, is not trivial. We leave this task to the next iteration
> of MRM refinement.
>2.2 Fault Isolation
> Fault isolation is initiated by the MRM manager. For different types
> of faults detected, various tools can be used to isolate the faults
> to small areas in the network. Currently, the tools available for
> this purpose includes but not limited to mtrace [MTRACE}, MIBs based
> debugging tools based, http-based status report mechanism and remote
> execution mechanisms.
> When one tool is not sufficient, a combination of tools can be
> applied. In general, MRM is designed to be flexible about the types
> of tools it can utilize. Integrating the functionality of other
> tools into MRM is an implementation issue for the MRM manager.
>2.3 The Protocol
> As stated above, the task of monitoring multicast reachability is
> accomplished by letting an MRM manager configure the MRM testers to
> perform fault detection and isolation tests. The MRM manager
> summarizes or displays the collected reports for the network
> operators, in an implementation specific way.
>Almeroth, Wei, Farinacci [Page 5]
> The MRM manager keeps a list of tester addresses. The relevant
> routing devices are administratively configured as candidate MRM
> testers. These testers will become active TSs and TRs once they
> accept and process requests from an MRM manager.
> We chose to use RTPv2 encapsulation for the following MRM messages:
> fault report messages from TRs and optionally some test data packets.
> This is to allow re-use of existing RTP based reception mechanisms.
> Note that despite the use of the RTPv2 packet format, the design
> goals and rules for the MRM message exchange protocol are entirely
> different from those specified in RTP.
> An MRM manager sends Test Sender requests to the TSs, and Test
> Receiver requests to the TRs.
> The MRM manager optionally transmits periodic beacon requests
> to the well-known MRM multicast address MRM-ADDR (224.0.1.111)
> that all TSs and TRs listen to. This beacon mechanism has three
> purposes:
> (1) For the TSs and TRs to learn the liveness of the MRM manager;
> (2) As a medium to periodically refresh requests, in order for
> testers to recover lost MRM messages, configurations or state
> (e.g. across reboots).
> (3) Inform a large group of test participants that an MRM session
> has been changed or cancelled.
> The use of beacon messages by the manager is optional primarily
> because multicast connectivity between the manager and TSs and
> TRs may not exist. As a result, while beacon messages may add
> robustness, they should not be relied on to provide critical
> functionality. While the manager chooses whether or not to
> send beacon messages, TSs and TRs must be prepared to handle
> these messages.
> The MRM manager may send a request to either a unicast address,
> or multicast address 224.0.1.111. When the message is sent via
> unreliable unicast transport (UDP), the recipient must send a
> positive acknowledgement after it has received that request.
> Unacknowledged request messages are retransmitted.
>Almeroth, Wei, Farinacci [Page 6]
> The MRM manager periodically transmits beacon messages to advertise its
> liveness to all MRM testers. This message is UDP-encapsulated. The
> sender's timestamp can be used to calculate the jitters in delay
> between subsequent beacon messages.
> The recommended default Beacon message interval is 1 minute. The MRM
> manager may piggyback the manager requests on the beacon messages.
> This potentially reduces the need to individually check and repair
> each tester's setup state, while still able to provide reliability
> through a soft-state refresh mechanism.
> A Test Sender request is first unicast delivered to a TS, then
> refreshed through multicast delivery via the MRM beacon mechanism.
> A Test Sender request specifies one of the following two ways to
> generate test packets:
> (1) Local packet trigger. This request includes the following
> parameters:
> (a) intervals between two consecutive test packets;
> (b) format and length of test packets (e.g. RTP/UDP);
> (c) multicast address for the test group.
> If a TS accepts this local packet trigger, it will start sending
> periodic test packets, at intervals specified in the MRM request
> message. The IP address of the MRM manager will be used as the ID
> for all test packets originated by the TS under this request. To
> detect loops and packet losses, all test packets also contain a
> monotonically increasing sequence number (if encapsulated in RTP,
> this would be the RTP sequence number).
> (2) Proxy packet trigger (see Section 5 for security impacts).
> This request lets a TS send a (sequence of) MRM test packet(s),
> using the IP source address provided by the manager request
> message. This request contains all parameters a local packet
> trigger has, plus a proxy-source address.
> This request is useful for monitoring intra-domain multicast
> connectivity for external sources. A proxy packet trigger can be
> used to inject packets into the local domain, pretending there is
> an active source external of the local domain. Inside the domain,
> as far as forwarding is concerned, these packets are
> indistinguishable from packets originated from a real external
> source. For security reasons, proxy packet triggers should be
> enabled very carefully.
>Almeroth, Wei, Farinacci [Page 7]
> TSR messages are also used to stop ongoing tests. By re-sending
> the original TSR packet, but with a holdtime of zero, a test can
> be stopped. NOTE: TRR messages with a holdtime of zero should
> also be sent to each test receiver participating in the test.
> An MRM status request is first addressed to a unicast address of a
> TR, and subsequently should be carried in the MRM manager beacon
> messages sent to 224.0.1.111.
> Each such request carries a holdtime of the request, after which the
> TR can safely discard any information collected. A TRR with a
> holdtime of zero implies that an ongoing test should be terminated.
> The TRR specifies how each TR should collect the reception data.
> The following are the request types for the TRs:
> (1) Monitor multicast group. This request has the following fields:
> (a) J-bit. If set, the TR will join the specified group, as if it
> were a host with a member of that group.
> If a tester did an IGMP join at the beginning of a test, when
> the MRM request expires, the IGMP group membership should be
> withdrawn.
> When a TR is instructed to join a data group of an existing
> application (e.g. a heartbeat [heartbeat] group), it is wise
> to assess the impact on the TR system if the data rate is
> non-trivial.
> Furthermore, the use of existing groups introduces uncertainty
> as to whether the source is actually transmitting. Because
> TRs expect a constant flow of packets, using existing group
> traffic, which may be bursty, introduces uncertainty at the
> receiver as to whether traffic is flowing but is being lost
> or not being sent.
> (b) The address of the group to be monitored;
> (c) List of source addresses to record reception quality
> information;
> (d) Threshold description for triggering fault reports.
>Almeroth, Wei, Farinacci [Page 8]
> This draft revision only specifies packet loss based
> threshold. A fault is detected if the packet loss percentage
> has reached the threshold during the specified time window for
> measurement. Once set, the width of this window is fixed. But
> the starting point (or left edge) of the window keeps moving
> forward.
> Reception quality data within the measurement window should be
> kept so that threshold calculations can be made continuously
> as the window moves forward in time.
> (e) Maximum and minimum delays to trigger fault report. The report
> is sent at a randomized delay between the minimum and the
> maximum value.
> (f) Type of error reports solicited. It is possible to specify an
> RTCP report (as if the test session uses RTP), or a native MRM
> report. Currently, MRM only supports RTP-based reports.
> (2) Fault isolation request. This request is sent after a fault is
> detected and identified by the MRM manager. It specifies the tool
> and its associated parameters.
> Details about this request message will be added in a future
> revision of the MRM specification.
> (3) Poll for receiver statistics. This instructs the TR to report the
> statistics (historic data) it has collected via Status Reports.
> The TR will send Status Reports, even if the fault threshold has
> not been reached. Section 2.3.2 describes the status report
> mechanism in detail.
> When large numbers of TRs are activated, a fault in the upstream of a
> tree may result in many TRs sending reports at the same time. To
> address the issue of possible report implosion, each TR may use one
> of the following two strategies:
> (1) Report via unicast message. The MRM manager assigns a pre-
> determined report-delay (as part of the configuration design
> task) to each TR. Each TR upon detecting a fault, will randomly
> delay the sending of its report based on the pre-set delay
> period. This would allow an MRM system to monitor networks with
> up to thousands of systems without unreasonable compromises in
> detection response times.
> (2) Each TR may be instructed to report the detected faults to the
> well-known MRM group address 224.0.1.111 using the RTCP format
> [RFC1889] and does back-off or suppression when duplicate reports
> from other Testers are seen. If using this strategy the manager
> should realize that using multicast to report a problem with
> multicast may not be particularly robust.
>Almeroth, Wei, Farinacci [Page 9]
> This method allows the use of existing RTP-based monitoring tools
> in the initial deployment and experiments with MRM. However, it
> will prevent the MRM manager from learning a complete list of
> receivers affected by a specific fault. When multicast routing is
> not working correctly, these reports may not be heard by the MRM
> manager, leaving faults undetected and not alarmed by the MRM
> manager. It is recommended that all designs include at least a
> subset of TRs that (take turns to) unicast their reports.
> There is ambiguity in MRM not hearing any fault report from a certain
> TR. It could be due to fault-free network status, the crash of the
> TR, or problems in the transport mechanism between the TR and the MRM
> manager. Requiring each TR to frequently report its liveness and to
> only do unicast fault report may work for a moderate number of
> testers, but may put undue burden on the network for larger numbers
> of testers. A compromising solution is to only report liveness from
> a critical portion of the network and do unicast fault report from a
> subset of the testers. The periodic liveness reports serve two
> purposes: (1) it provides evidence that the tester is still alive;
> (2) it indicates the conditions of the tester functions. The
> request-ack messages are used as tester liveness reports.
> Note that the fault isolation phase does not necessarily require the
> MRM manager to send a Fault Isolation Request to a TR. E.g, in a
> typical network today, a third party mtrace issued by the MRM manager
> may be sufficient to identify the faulty hop excessively dropping
> packets if the tester is not completely blacked out.
> These reports are sent by the TRs to the MRM manager, in response to
> a status request.
> For now, we use RTP [RFC1889] "receiver report (RR)" packet format to
> carry receiver's status reports. It is expected that the MRM-native
> report format (to be defined in future draft revisions) will carry
> more useful information about the routing state and statistics.
> Please refer to RFC1889 for details on the packet formats. Here we
> define the few RTCP items used by MRM (or loosely referred to as RTP
> profile for MRM):
> SSRC (Synchronization source) of packet sender:
> IP address of the Test Sender.
> Extended highest sequence number received:
> Highest sequence number seen by the Test Receiver.
> Fraction loss:
> Percent loss of Test Sender data.
>Almeroth, Wei, Farinacci [Page 10]
> Cumulative number of packets lost:
> Total number of RTP data packets from SSRC lost within this
> reception window period.
> Inter-arrival Jitter:
> Set to zero when sent, ignored when received.
> When this report is UDP encapsulated and unicast addressed to the MRM
> manager, it is explicitly acknowledged. The acknowledgement packet
> contains the RTCP header portion of the original packet after the MRM
> header.
> Once all TS and TR systems are configured, they join the well-known
> MRM control group MRM-ADDR (224.0.1.111) and listen to the well-known
> MRM UDP port MRM-MANAGER-PORT (679).
> The MRM beacon messages are periodically sent to 224.0.1.111 UDP
> port 679.
>4. Message Formats
> By default, MRM control messages are encapsulated inside UDP, and an
> IP authentication header (AH) [KA98], is inserted in between the IP
> header and the UDP header, as shown below:
> | IP Header | AH | UDP header | MRM header | MRM payload |
> The MRM status report in RTCP format is:
> | IP Header | AH | UDP header | RTCP Rcvr Report | MRM header |
> The MRM ACK packet format is:
> | IP Header | AH | UDP header | MRM header | RTCP Header |
>Almeroth, Wei, Farinacci [Page 11]
> The inserted AH is reproduced below:
> 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
> | Next Header | Payload Len | RESERVED |
> | Security Parameters Index (SPI) |
> | Sequence Number |
> | Authentication Data (variable) |
> As specified in [KA98], the following are the default values for the
> fields above:
> Next Header: 17, the value for UDP protocol.
> Payload Len: 5, when MD5 is used (total length is 7 32-bit words).
> RESERVED: 0 when sent, ignored when received.
> SPI: 0 - 50, when using configured MD5 keys
> Sequence Number: the sequence number
> Authentication Data: message digest
> The MRM message header contains 4 32-bit words.
> |Version| Type | Code | Holdtime |
> | Target IP address |
> |M| Reserved | MRM message length |
> | Timestamp (in milliseconds) |
> Version: 4 bits
> This revision defines version 1 of MRM.
>Almeroth, Wei, Farinacci [Page 12]
> Type: 4 bits
> The defined message types are:
> 0 = Beacon (from MRM manager to all testers)
> 1 = TS Request (from MRM manager to Test Senders)
> 2 = TR Request (from MRM manager to Test Receivers)
> 3 = Status Response (from TR to the MRM manager)
> 4 = TS Request Ack (from TS to MRM manager)
> 5 = TR request Ack (from TR to MRM manager)
> 6 = Status Response Ack (from MRM manager to TR)
> Code: 8 bits
> Defined according to each packet type.
> Holdtime: 16 bits
> Maximum duration in seconds this message should be honored.
> Target IP address: 32 bits
> The unicast address of the intended recipient of this message.
> M: 1 bit,
> 0: last MRM request message in this packet.
> 1: more MRM request messages follow in the same packet.
> When multiple MRM messages are grouped into one packet, the IP/AH/UDP
> headers of the second and all subsequent MRM messages are omitted. The
> total length of the IP packet will reflect the the sum of lengths of
> all MRM messages in the packet.
> This message is UDP encapsulated, addressed to UDP port MRM-MANAGER-
> PORT. The outstanding Test Sender Requests and Test Receiver
> Requests are included in the beacon message. The individual MRM
> headers are included with these TSR/TRRs.
> There are two code values for a TSR:
> 0: Local packet trigger
> 1: Proxy packet trigger
> NOTE: A host-based implementation is not expected to provide
> proxy packet capability.
> Following the MRM message header are the fields for the source
> specification request:
>Almeroth, Wei, Farinacci [Page 13]
> | UDP port of test packets |R| S | LEN | Reserved |
> | Test group address |
> | Inter-packet delay (millisecond) |
> | Proxy source IP address (for proxy packet trigger) |
> UDP port of test packets: 16 bits
> UDP port of test packets.
> R: 1 bit
> 0: Tester will originate RTP/UDP encapsulated test packets
> 1: Tester will originate another kind of packet (not used)
> S: 2 bits
> 00: send on the targeted interface only
> 01: send on all the multicast enabled interfaces
> 10: send on test-send enabled interfaces
> 11: Unused
> LEN: 3 bits (optional)
> Size of the packets to be sourced. The length field represents
> a multiple of 16 bytes. The range of possible packet sizes is
> 16 bytes to 2048 bytes (2^7)*(16 bytes). The LEN field is
> optional. If ignored, test senders should send 16 byte packets.
> Reserved: 10 bits
> Set to zero when sent. Ignored with received.
> Inter-packet delay: 32 bits
> Number of milliseconds between consecutive test packets.
> Test group address: 32 bits
> Multicast address of the test group.
> Proxy source IP address: 32 bits
> IP address of the source to proxy packet for. This field
> exists only for a proxy packet trigger request.
> The following are code values for status request messages:
> 0: Monitor multicast group (Monitor request)
> 1: Poll for receiver statistics (Poll request)
> 2: Fault isolation request (not used in this revision)
>Almeroth, Wei, Farinacci [Page 14]
> Message format for monitor and poll requests:
> |J|R| Reserved | Number of sources to monitor |
> |Thres index (0)| Pkt loss (%) | Reception window (seconds) |
> | Min report delay (seconds) | Max report delay (seconds) |
> | Max startup delay (seconds) | Reserved |
> | UDP port of test packets | UDP port for status reports |
> / Threshold description block /
> | IP address of Source 1 |
> | Inter-Packet delay interval from source 1 |
> | IP address of Source n |
> | Inter-Packet delay from source n |
> J: 1 bit
> 0: Don't join the multicast group to be monitored.
> 1: Join the multicast group to be monitored.
> R: 1 bit
> 0: Fault report should be sent in RTCP format
> 1: Fault report should be sent in native MRM format (not used).
> Reserved:
> Zeroed when sent, ignored when received.
> Number of sources to monitor: 16 bit
> The number of sources this target tester should monitor. When
> all sources for the test group are monitored, this field is
> set to 1, and the corresponding source address field is set
> to 0.0.0.0.
> Thres index: 8 bits
> Always 0. Index of the criteria for determining a threshold
> for a fault. The value of this index determines the content
> for the "Threshold description Block".
>Almeroth, Wei, Farinacci [Page 15]
> Pkt loss (%): 8 bits
> Percentage of packet loss. A criteria to determine whether a
> fault has occurred.
> Max report delay (seconds): 16 bits
> Maximum number of seconds within which a fault report must be
> sent after it is detected.
> Min report delay (seconds): 16 bits
> Minimum number of seconds a fault report needs to be sent after
> it is detected. A report should not be sent in less than this
> delay.
> Max startup delay (seconds): 16 bits
> Max number of seconds the TR can wait before the start of the
> test. The test is considered started if a test packet is
> received, or the "max startup delay" has passed after the
> receipt of this request.
> Reception window (seconds): 16 bits
> Number of seconds used for calculating packet loss percentage.
> UDP port of data packets: 16 bits
> UDP port test data packets use.
> UDP port of status report packets: 16 bits
> UDP port of status report packets.
> Threshold description block: 0 bit
> Variable length, depending on "Thres index". This revision only
> defines threshold index 0, with no threshold description block.
> The IP multicast address for the test group.
> IP address of source 1 .. n: 32 bits
> The IP address of the sources the targeted tester should monitor.
> When the address is 0.0.0.0, all sources to this group will be
> monitored.
> Inter-packet delay from source 1 .. n: 32 bits
> Intervals between consecutive packets from the source
> (milliseconds).
> This MRM revision uses the reception report (RTCP) format based on
> Section 2.3.2. Future revisions will define MRM specific report
> formats.
>Almeroth, Wei, Farinacci [Page 16]
>4.6 MRM Test Packet
> MRM test packets are RTPv2/UDP encapsulated. The RTPv2 packet header
> is replicated below for easy of description.
> |V=2|P|X| CC |M| PT | sequence number |
> | timestamp |
> | synchronization source (SSRC) identifier |
> | IP address of MRM manager |
> CC:
> Set to 0 when sent, ignored when received.
> M:
> PT:
> Sequence number:
> Sequence number. Set to 0, when a tester is activated.
> Timestamp:
> System timestamp, in milliseconds.
> SSRC:
> IP address of the tester, or a configured 32-bit number that
> uniquely identifies the tester.
> The Acknowledgement messages for the Test Sender Request and the
> Status Request provide guarantees that the requests are indeed
> received by the testers, instead of being lost. The acknowledgement
> packets contain the MRM header and trailer for the respective
> messages, except that the message length and authentication data
> fields are recalculated.
> All MRM messages should be authenticated with the MD5 mechanism
> specified here. The fields in the messages are transmitted in the
> clear. Packets that fail the authentication check are discarded by
> the receivers.
>Almeroth, Wei, Farinacci [Page 17]
> The sender of the MRM message decides which authentication key
> is used.
> (1) The MRM message length field is filled with the number of
> bytes in the message;
> (2) The rest of the message is composed;
> (3) The IPSEC AH is constructed;
> (4) The "authentication data" field is zeroed;
> (5) The MRM authentication Key (16 byte long) is appended
> to the MRM message.
> (6) The pad for the key is added. The digest is calculated and
> written into the "authentication data" field.
> The part with the MD5 secret is not transmitted.
> The receiver follows the following steps when processing an incoming
> message:
> (1) The digest is stored away and the "authentication data"
> field zeroed;
> (2) It finds the key according to the value of "Key ID", and
> the key is appended and the packet properly padded;
> (3) A new digest is calculated.
> A message is discarded if the new digest is different from the one
> carried in the packet.
>5.3 Key Management
> We expect to rely on manual key distribution in the initial stages.
> And MRM should be able to utilize the standard secure key management
> mechanism when it becomes available.
>Almeroth, Wei, Farinacci [Page 18]
> The strength of the security mechanism here depends on the strength
> of the key and the MD5 algorithm.
> Insufficiently protected TSs and TRs (e.g. by weak keys) can be
> subject to attacks that can cause the TSs and TRs to take actions
> causing harm to the network.
> MRM is originally targeted at two types of users: network operation
> centers that provide production quality services; and network
> administrators who oversee semi-production or experimental multicast
> services. The former often rely on SNMP-based tools for management
> tasks and typically desire all types of monitoring functionalities to
> be wrapped into the same set of tools. While the later, who usually
> set the stage for production quality offerings, do not normally rely
> on SNMP-based tools and favor task-oriented tools.
> For this reason, this document specifies the native MRM messages and
> operations. A companion document will define the MRM MIB that can
> accomplish the majority of the native MRM tasks.
> The example shown in this section is for illustration purpose only,
> and does not cover all possible functionalities of the MRM framework.
> Neighbor. T1 T2 . Neighbor
> Domain . +----+ +----+ +-----+ . Domain
> ----| BR1|-----------| R2 |-----------| BR3 |--------
> | R4 | | R5 |
> . T3 /
> --------| R6 |-----------/
> | MRM Manager |
>Almeroth, Wei, Farinacci [Page 19]
> The above is a simple topology used to demonstrate the use of various
> MRM features. Border routers BR1, BR3 and an internal router R6 are
> administratively configured as candidate MRM Testers. The MRM manager
> configures T1 to be a TS, and T2,T3 to be TRs. The following are the
> messages sent by the MRM components.
> (1) MRM manager sends Test Sender request (TSR) to T1.
> Req1 = {Local packet trigger,
> test packet interval = 60,000 (ms),
> RTP/UDP test packet = TRUE,
> Test group = 239.255.255.2}
> T1 acknowledges receipt of Req1.
> (2) MRM manager sends TR request Req2 to T2. Req2 has the following
> content:
> J-bit = TRUE,
> list of source addresses = {T1's IP address},
> threshold for fault detection = {20% loss over 10 minutes},
> max delay for fault report = 10 seconds,
> min delay for fault report = 0 seconds,
> Test group = 239.255.255.2,
> T2 acknowledges receipt of Req2. Req2 is retransmitted if the
> retransmission timer expires.
> (3) MRM manager sends TR request Req3 to T3. Similar to Req2,
> except the target is T3, and,
> max delay for fault report = 20 seconds,
> min delay for fault report = 10 seconds
> By using different (min, max) report times, it can avoid report
> implosion at the MRM manager, when a fault is detected by T2 and T3
> at the same time.
> (4) MRM manager periodically sends beacon messages, carrying Req1 and
> Req2, Req3. The holdtime is set to the remaining lifetime of the
> original request.
> Assume T1 has a fault such that it can only forward 1% of all
> multicast packets, the fault is detected by T2 and T3. T2 randomly
> delays between 0-10 seconds, and sends a fault report to the MRM
> manager. The MRM manager acknowledges this report. T3 randomly
> delays between 10-20 seconds, and sends its fault report to the MRM
> manager, which is also acknowledged. This concludes the fault
> detection phase.
>Almeroth, Wei, Farinacci [Page 20]
> In the fault isolation phase, assume the MRM manager sends a third
> party mtrace request to T2 or T3, and isolates the fault to between
> T1, R2 and T1, R4. The MRM manager can then issue an an alarm to the
> network operator, with proper descriptions of the problem.
> The operation for fault isolation phase might be more complicated for
> other types of fault, e.g. if T1 has lost the ability to forward
> multicast packets completely, T2 and T3 wouldn't have any multicast
> routing state or statistics for mtrace to work, some other mechanisms
> would have to be put in use.
>9. Acknowledgment
> We'd like to thank John Meylor, Beau Williamson, Stephen Deering,
> Ishan Wu, Louis Mamakos, Manoj Leelanivas, David Meyer, Bill Fenner
> and Dave Thaler for their comments and suggestions. We'd like to
> especially TY Lin and Kamil Sarac for filling in missing details from
> the previous version of the specification.
> Kevin Almeroth
> Department of Computer Science
> University of California
> Santa Barbara, CA 93106-5110
> almeroth at cs.ucsb.edu
> Liming Wei
> Siara Systems, Inc.
> 300 Ferguson Drive
> Mountain View, California 94043
> lwei at siara.com
> Dino Farinacci
> cisco Systems, Inc.
> 170 West Tasman Drive
> San Jose, CA 95134
> dino at cisco.com
>Almeroth, Wei, Farinacci [Page 21]
>11. References
> [mtrace] Steven Casner, Bill Fenner et al. The mtrace tool.
> [mrm-use] Kevin Almeroth, Liming Wei, "Justification and Use of MRM",
> draft, Jan 15, 1999.
> [aboba] Bernard Aboba, "The Use of SNTP as a Multicast Heartbeat",
> Draft, draft-ietf-mboned-sntp-heart-02.txt.
> [ping] Jon Postel, "Internet Control Message Protocol", RFC792,
> Information Sciences Institute, 1981.
> [UDP] Jon Postel, "User Datagram Protocol", RFC768. Information
> Sciences Institute.
> [scope] Dave Meyer, "Administratively Scoped IP Multicast",
> Draft, draft-ietf-mboned-admin-ip-space-03.txt.
> [MD5] R. Rivest, "The MD5 Message-Digest Algorithm", RFC1321,
> April, 1992
> [KA98] Kent Stephen, Randall Atkinson, "IP Authentication Header",
> "draft-ietf-ipsec-auth-header-07.txt", July 1998
> October 1999 -- revisions since draft-ietf-mboned-mrm-00.txt
> (1) Added a TS length field to allow test send packets to be
> specified between 16 bytes and 2048 bytes in 16 byte
> increments.
> (2) Made usage of beacon messages by the manager optional.
> Test agents are required to be able to process beacon
> messages.
> (3) Monitoring existing groups is relegated to a later version
> because of the difficulty in monitoring the source to
> determine if it is sending a packet. When an MRM Test
> Source is used, Test Receivers know when, how many, and
> for how long packets will be sent. If no packets are
> received the test receiver knows to report 100% loss.
> This assumption is not possible when monitoring existing
> groups.
> (4) Added additional detail about packet formats and packet
> handling procedures to reduce ambiguity.
>Almeroth, Wei, Farinacci [Page 22]
