Distributed Powerpoint
Robert Olson
olson at mcs.anl.gov
Mon Jun 28 13:20:57 CDT 1999
I've put up a zipfile of the current distributed powerpoint stuff at
http://www-unix.mcs.anl.gov/~olson/AG/Software/NT/dppt2.zip
BIG CAVEAT about this stuff: it is barely at all release engineered... I'm
mostly releasing it because of the interest folks have in it. If someone has
some cycles for java development, I've got a ton of ideas on how to turn it
into a useful tool.
You'll need PowerPoint and the microsoft java interp installed on the machine.
I've found that the clean NT4 install on the new dipslay machine I just got
works fine.
To use, unzip into a directory.
Edit config.bat to set SERVER to the hostname of the machine that will be a
server for the dppt session.
On that server, run two scripts:
start registry
start agserv
On the machine you are going to drive the presentation from, run:
master full-path-to-ppt-file
Note that powerpoint wants a full path, even if you're in the same directory.
Now here's the cool thing I just discovered. If you put the presentation up on
a website, ppowerpoint knows how to open it given a url. So, you could do
something like
master http://www.somewhere.org/your/pres.ppt
On a machine that wants to watch the presentation, run
client full-path-to-ppt-file
or
client http://www.somewhere.org/your/pres.ppt
let me know if it works!
---bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/19990628/07e343bd/attachment.htm>
