High-end audio
Tom Coffin
tcoffin at ncsa.uiuc.edu
Thu Jun 10 17:31:04 CDT 1999
ok - so if we go with the layla card, then the audio computer
should be a win98 os instead of the redhat linux. correct?
At 04:00 PM 6/10/99 -0600, Paul Hubbard wrote:
>> Anyone familiar with this audio card? Looks like it could be a good
>> addition. Optical interconnect to the actual audio gear is nice,
>> ultimate isolation from the noisy computer equipment.
>ADAT denotes Alesis-format _digital_ signals, as used in their 8-channel
>recording units. The Sonorus card, therefore, has only digital inputs, and
>what we need is multiple analog inputs.
>For the same price range ($750) I'd recommend the Event Electronics
'Layla'
>board, see http://www.event1.com/products/layla.html for details. 8 analog
>inputs, features galore.
>We went and looked around today, and the Layla is a good choice if you
have the
>money. However, the card will only work under Windows 95/98, and maybe NT
>sometime in the future. One could probably run this on the same machine
as the
>echo cancellation unit. We're looking at this, but will try the SB128
cards
>before we buy one.
>Another option is a Yamaha card - I don't know what this one costs, but
the
>specs look quite good. Anyone out there used one?
>http://www.yamaha.com/cgi-win/webcgi.exe/DsplyModel/?gHDR00008DS2416
>Alas, it's also a Win9x only product.
>In other audio suggestions, I'd recommend adding a good equalizer and
>compressor/limiter to the list. The EQ is very useful for tuning the
room and
>speakers, and the c/l unit prevents damage from dropped mics, RF
glitches, and
>so forth. The DBX 2231 is a nice unit that has both in one box, and
we've gone
>ahead and ordered one for this project, as we've used them in our VR
lab with
>good results. This should be used on the main mix, between the mixer
and the
>monitors.
>Yet Another Piece of Gear is the DBX 1046 quad compressor/limiter - we
plan on
>using one channel for each microphone input, as this will allow fine
control of
>their dynamic range, which should help with the echo cancellation unit.
A bit
>pricy like all DBX gear, but it has _lots_ of flashing lights to show your
>boss.
>For larger rooms, the Mackie HR824 monitors make a good choice - YMMV, but
>they're only ~75 more than the Genelecs, and have much better specs.
>Info at http://www.mackie.com/Products/HR824.asp, another choice for
larger
>venues is their SRM450 at http://www.mackie.com/Products/SRM450.asp
>-Paul
>Paul Hubbard phubbard at unm.edu
>"Charm's in limited supply, and refusing to stretch"
___________________________________________________________
Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
