Software to try: Video Resource Manager
Tom Coffin
tcoffin at ncsa.uiuc.edu
Thu Jul 15 12:25:17 CDT 1999
alan Craig has a software package which archive elists
see cavernus elist for an example - could be useful
acraig at ncsa.uiuc.edu
At 11:12 AM 7/15/99 -0600, Richard Coffey wrote:
>Everytime you guys send out email, I think, wouldn't it be nice if this
were
>on a website? If this is, could you please point me in the right
direction? If
>not, maybe it would serve us well to setup a email archive that was
published
>on the website...
>Just a thought,
>Richard ;-)
>Robert Olson wrote:
>> I've packaged up a first cut at some chunks of framework for
configuring &
>> running the video capture for an AG node.
>> It's a pair of Java apps. The first is setup-config. You run it on the
>> video capture machine (with no vic's running) like this:
>> /usr/local/ag/apps/vrm/setup-config config-file
>> and it probes the machine to see how many video capture cards the
machine
>> has and what device names they are. It then brings up a GUI with a panel
>> for each card, on which you can select the input port you wish to use
and
>> the purpose of the video (presenter/audience/main).
>> The test buttons fire up a vic set to transmit with the parameters
you've
>> chosen. This is so that you can figure out which video is which for
>> multiple cameras, without tracing cables and figuring out the slot to
>> capture card device mapping.
>> There is also a field for the AG node name.
>> When the configuration is as you like it, press the Write Output button.
>> This will write the configuration to the file you specified on the
command
>> line. The configuration file contains XML text describing your capture
>> machine. This is one input to be fed to the resource manager itself.
>> The second app is the video resource manager. It reads the XML file
>> generated above, and generates a GUI with which you can start and
stop the
>> vic sessions for capture.
>> Invocation is:
>> /usr/local/ag/apps/vrm/vrm -c config-file -t ttl address
>> For instance,
>> /usr/local/ag/apps/vrm/vrm -c video-config.geode.mcs.anl.gov
-t 127
>> 224.1.2.3/12000
>> You should see a GUI with a pane per card and the address info. You can
>> start individual captures via the start buttons in the pane, or all
at once
>> with the start all button.
>> Installation:
>> These apps require jdk1.2 and a couple XML packages. I've repackaged the
>> vendor tars as Linux RPMs to ease the installation process. All it
should
>> take to install the tools is the following script (that can be found at
>> http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/install-ag-0 )
>> #!/bin/sh
>> rpm_base=http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS
>> rpm -i $rpm_base/jdk-1.2-1.i386.rpm
>> rpm -i $rpm_base/gmd-xql-1.0.1-1.i386.rpm
>> rpm -i $rpm_base/xml4j-2.0.11-1.i386.rpm
>> rpm -i $rpm_base/java-getopt-1.0.6-1.i386.rpm
>> rpm -i $rpm_base/ag-vrm-1.00-1.i386.rpm
>> Let me know how this works for you. Keep in mind again that this is
>> completely untested outside the ANL AG environment, and is very roughly
>> release engineered (hardcoded paths, etc). It will work on an SGI,
but not
>> in the RPM form. Source RPMS are available at
>> http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/SRPMS/.
>> --bob
___________________________________________________________
Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
