Multicast debugging
Bill Nickless
nickless at mcs.anl.gov
Mon Jul 12 09:12:56 CDT 1999
At 08:38 AM 7/12/99 -0700, Robert Olson wrote:
>At 08:31 AM 7/12/99 -0500, Linda Winkler wrote:
>>Unfortunately, mtrace on ciscos is broken. known problem for a while.
>>no fix in site.
>Are there any alternate debugging tools?
>--bob
With session tools running, one looks at the routers to see if there are
mroutes in place. On a Cisco, one runs
show ip mroute 224.2.177.155
Which gives you a listing including entries like this
destiny#show ip mroute 224.2.177.155
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, C - Connected, L - Local, P - Pruned
R - RP-bit set, F - Register flag, T - SPT-bit set, J - Join SPT
X - Proxy Join Timer Running
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.2.177.155), 3w4d/00:02:59, RP 130.202.192.1, flags: SJCF
Incoming interface: ATM4/0, RPF nbr 130.202.128.1
Outgoing interface list:
ATM1/0.3, Forward/Sparse-Dense, 5d01h/00:02:14
(128.197.160.83, 224.2.177.155), 00:23:09/00:02:59, flags: CJT
ATM1/0.3, Forward/Sparse-Dense, 00:23:09/00:02:14
(140.221.8.37, 224.2.177.155), 00:00:30/00:02:29, flags: CT
Incoming interface: ATM1/0.3, RPF nbr 0.0.0.0
ATM4/0, 130.202.128.1, Forward/Sparse-Dense, 00:00:30/00:02:29
[...many more records deleted]
This tells you that there is traffic on the 224.2.177.155 group (otherwise
there would be no reports at all) and that traffic is being heard from
128.197.160.83 and 140.221.8.37 at this router.
Note that there is no detectable difference between a broken network and
the lack of a multicast sender--both cases show up as no record in the
multicast router tables. That's why it's so ipmortant to leave multicast
senders running during debugging.
When debugging multicast passing between Autonomous Systems, one runs Cisco
router commands like
show ip mroute <group>
show ip mbgp <etc>
show ip msdp <etc>
Then one discusses the resulting output with the network management on the
other side of the link. Configurations are tweaked, new router software is
installed, and routers are rebooted until the M-BGP and MSDP protocols are
working correctly.
Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
