mbone debugging: funny-looking NCSA <-> ANL mtraces
Stuart Levy
slevy at ncsa.uiuc.edu
Thu Jul 1 15:20:18 CDT 1999
Here are some mtraces, taken just now (mid-session)
from niri.ncsa.uiuc.edu (from which I see lots of mbone dropouts,
often as regular spikes appearing at ~5sec intervals,
sometimes worse)
to some machines at Argonne (the "Workshop" and "FL Library" senders).
In each case, vic's "mtrace from" (ANL->NCSA) gave a sensible result:
Mtrace from 140.221.8.39 to 141.142.220.60 via group 224.2.177.155
Querying full reverse path...
0 niri.ncsa.uiuc.edu (141.142.220.60)
-1 pigpen.ncsa.uiuc.edu (141.142.220.120) PIM thresh^ 0
-2 charlie-atm1-0-7.ncsa.uiuc.edu (141.142.11.150) PIM thresh^ 0
-3 cs-atm0-0-12.ncsa.vbns.net (141.142.11.1) Unknown protocol code 8 thresh^ 0
-4 cs-atm0-0-6.dng.vbns.net (204.147.129.246) Unknown protocol code 6 thresh^ 0 Unknown error code 8
-5 bluto-vbns.ctd.anl.gov (192.5.170.129) PIM thresh^ 32
-6 destiny.mcs.anl.gov (130.202.128.5) PIM thresh^ 6
-7 geode.mcs.anl.gov (140.221.8.39)
Round trip time 349 ms
Waiting to accumulate statistics... Results after 9 seconds:
Source Response Dest Packet Statistics For Only For Traffic
140.221.8.39 141.142.220.60 All Multicast Traffic From 140.221.8.39
v __/ rtt 113 ms Lost/Sent = Pct Rate To 224.2.177.155
140.221.11.253
130.202.128.5 destiny.mcs.anl.gov
v ^ ttl 6 8556/14043= 61%1560 pps 5/721 = 1% 80 pps
130.202.128.1
192.5.170.129 bluto-vbns.ctd.anl.gov
v ^ ttl 32 2/5487 = 0% 609 pps 1/716 = 0% 79 pps
192.5.170.130
204.147.129.246 cs-atm0-0-6.dng.vbns.net Unknown error code 8
v ^ ttl 33 -443/14258= -2%1584 pps -25/715 = -2% 79 pps
204.147.129.245
141.142.11.1 cs-atm0-0-12.ncsa.vbns.net
v ^ ttl 34 11/9317 = 0%1035 pps 0/740 = 0% 82 pps
141.142.11.2
141.142.11.150 charlie-atm1-0-7.ncsa.uiuc.edu
v ^ ttl 35 1/7238 = 0% 804 pps 0/740 = 0% 82 pps
141.142.11.149
141.142.220.120 pigpen.ncsa.uiuc.edu
v \__ ttl 36 3249 361 pps 740 82 pps
141.142.220.60 141.142.220.60
Receiver Query Source
Mtrace from 140.221.8.53 to 141.142.220.60 via group 224.2.177.155
-7 jade.mcs.anl.gov (140.221.8.53)
Round trip time 63 ms
Waiting to accumulate statistics... Results after 10 seconds:
140.221.8.53 141.142.220.60 All Multicast Traffic From 140.221.8.53
v __/ rtt 532 ms Lost/Sent = Pct Rate To 224.2.177.155
140.221.11.253
v ^ ttl 6 8578/14331= 60%1433 pps 4/902 = 0% 90 pps
130.202.128.1
v ^ ttl 32 1/5746 = 0% 574 pps -1/898 = 0% 89 pps
192.5.170.130
v ^ ttl 33 685/14505= 5%1450 pps 40/899 = 4% 89 pps
204.147.129.245
v ^ ttl 34 29/8602 = 0% 860 pps 0/859 = 0% 85 pps
141.142.11.2
v ^ ttl 35 5/6519 = 0% 651 pps -1/859 = 0% 85 pps
141.142.11.149
v \__ ttl 36 2156 215 pps 860 86 pps
But "Mtrace to" (NCSA->ANL) fails without getting anywhere
(Timed out receiving responses):
Mtrace from 141.142.220.60 to 140.221.8.53 via group 224.2.177.155
Querying full reverse path... * switching to hop-by-hop:
0 jade.mcs.anl.gov (140.221.8.53)
-1 * * * Timed out receiving responses
Perhaps receiver 140.221.8.53 is not a member of group 224.2.177.155,
or no router local to it has a route for source 141.142.220.60,
or multicast at ttl 64 doesn't reach its last-hop router for that source
Mtrace from 141.142.220.60 to 140.221.8.39 via group 224.2.177.155
0 geode.mcs.anl.gov (140.221.8.39)
Perhaps receiver 140.221.8.39 is not a member of group 224.2.177.155,
