Fwd: I-D ACTION:draft-ietf-mboned-mdh-02.txt
    Robert Olson
    olson at mcs.anl.gov
    Fri Aug 13 08:12:32 CDT 1999
FYI.
>X-Authentication-Warning: network-services.uoregon.edu: listserv set
>sender to owner-mboned at network-services.uoregon.edu using -f
>To: IETF-Announce:;
>Cc: mboned at network-services.uoregon.edu
>From: Internet-Drafts at ietf.org
>Reply-to: Internet-Drafts at ietf.org
>Subject: I-D ACTION:draft-ietf-mboned-mdh-02.txt
>Date: Fri, 13 Aug 1999 07:01:47 -0400
>Sender: owner-mboned at network-services.uoregon.edu
>X-Archive: ftp://ns.uoregon.edu/mailing-lists/mboned
>X-HTTP: http://ns.uoregon.edu/~dmm/MBONED
>X-Subscribe: majordomo at ns.uoregon.edu
>X-Unsubscribe: majordomo at ns.uoregon.edu
>A New Internet-Draft is available from the on-line Internet-Drafts
>directories.
>This draft is a work item of the MBONE Deployment Working Group of the IETF.
>         Title           : Multicast Debugging Handbook
>         Author(s)       : D. Thaler, B. Aboba
>         Filename        : draft-ietf-mboned-mdh-02.txt
>         Pages           : 34
>         Date            : 12-Aug-99
>This document serves as a handbook for the debugging of multicast
>connectivity problems. In addition to reviewing commonly encountered
>problems, the draft summarizes publicly distributable multicast
>diagnostic tools, and provides examples of their use, along with
>pointers to source and binary distributions.
>A URL for this Internet-Draft is:
>http://www.ietf.org/internet-drafts/draft-ietf-mboned-mdh-02.txt
>Internet-Drafts are also available by anonymous FTP. Login with the username
>"anonymous" and a password of your e-mail address. After logging in,
>type "cd internet-drafts" and then
>         "get draft-ietf-mboned-mdh-02.txt".
>A list of Internet-Drafts directories can be found in
>http://www.ietf.org/shadow.html
>or ftp://ftp.ietf.org/ietf/1shadow-sites.txt
>Internet-Drafts can also be obtained by e-mail.
>Send a message to:
>         mailserv at ietf.org.
>In the body type:
>         "FILE /internet-drafts/draft-ietf-mboned-mdh-02.txt".
>NOTE:   The mail server at ietf.org can return the document in
>         MIME-encoded form by using the "mpack" utility.  To use this
>         feature, insert the command "ENCODING mime" before the "FILE"
>         command.  To decode the response(s), you will need "munpack" or
>         a MIME-compliant mail reader.  Different MIME-compliant mail readers
>         exhibit different behavior, especially when dealing with
>         "multipart" MIME messages (i.e. documents which have been split
>         up into multiple messages), so check your local documentation on
>         how to manipulate these messages.
>Below is the data which will enable a MIME compliant mail reader
>implementation to automatically retrieve the ASCII version of the
>Internet-Draft.
>Content-Type: text/plain
>Content-ID:     <19990812120404.I-D at ietf.org>
>ENCODING mime
><ftp://ftp.ietf.org/internet-drafts/draft-ietf-mboned-mdh-02.txt>
