[AG-DEV] Suggestion
Andrew Danson
Andrew.Danson at newcastle.edu.au
Wed May 30 18:21:58 CDT 2012
Hi Salim and Tim,
May I make a suggestion with the script?
It seems from the feedback on the mail list that there is a lot of variation between the different operating systems and sometimes even between different versions ofthe same OS. Now rather than having to script every possible alternative, perhaps it would be best to make a sensible guess for each system as the default, and allow users of the script to specify the path either interactively (preferably) or on the command line when it fails.
Cheers
Andrew
