[AG-DEV] Setting up Build Environment
Andrew Danson
Andrew.Danson at newcastle.edu.au
Thu Jul 26 01:30:13 CDT 2012
Hi Guys,
I've noticed that there is some source on sourceforge so I decided to check out
a copy of the source and see what I can do with it.
Now I've followed the instructions for setting everything up so I can run the software
from the development environment in order to be able to test code. But when trying to
run the venue client I get this error message...
file ".../Accessgrid/Preferences.py". Line 12, in <module>
From AccessGrid.interafaces.AGNodeService_client import AGNodeServiceIW
ImportError: No module named AGNodeService_client
[andrew at ...]$
I was wondering If I've missed a step or if I'm missing some files, or perhaps there is some configuration I need to do in order to the source running. If anyone could provide some help that would be awesome :-)
Cheers
Andrew
