[AG-DEV] RAT corrupt sound
Ушаков Андрей
sorcchan at gmail.com
Wed Nov 10 04:37:05 CST 2010
Hello all!
I have a problem with RAT on Fedora 11, 12. Received sound has a lot
of jamming what sounds like ugly electronic noise. I try to solve this
problem by myself since may of 2010, and I found some solution but
still not found problem source and cannot fix it but lower sound
corruption. I interesting only 48kHz Mono mode, btw. How can I fix it?
First, I checkout latest version of RAT from repository and build a
debug version of common lib and rat itself. And first thing what I
find is horrible spamming of message:
RTP packet queue overflow.
So I just enlarge a little this queue. Sound become slightly better.
Next my target was find why messages
Insert X samples.
Playout buffer shift back X samples.
occurs and sound has jamming and flipping. I find out what it cause
because there is some unsynchronization detecte in function
int source_check_buffering(source *src) in file source.c
I have no idea why it does. And I don't know how to debug it. Hardware
problem? Software? ALSA? No idea. Then I go to the ALSA settings and
starts an experiments to configure default ALSA device. And I find a
configuration what almost do a sound well!! So there it is:
1) I add .asoundrc file in my home directory:
defaults.ctl.!card Intel
defaults.pcm.!card Intel
defaults.pcm.dmix.!rate 48000
defaults.pcm.dmix.!format S16_LE
2) And, important, I manually setup buffers sizes for default ALSA
device directly in dsnoop.conf and dmix.conf. And channel count and
binding also. There it is:
I add to dsnoop.conf:
channels 2
period_time 10000
periods 16
bindings.0 0
(very short fragments)
And to dmix.conf:
channels 1
period_time 300000
periods 16
(laaaarge fragments)
And VOILA! sound become clean and very good ... almost. Once-twice in
5 min interval randomly occurs same flips and messages:
Insert X samples.
That is my story. If some one know this problem and know how to debug
and fix it, lets discuss! Also, I can send my hardware and software
configuration if needed.
And at last, I wrote some CLI interface to RAT what useful when RAT
work in -noui mode and I can share it if some one interested about it
:) Its not perfect may be because I have no one friend who understand
the mbus and RAT :) But it works.
