[AG-DEV] Issue communicating with Event Channel
krishna chandu
krishna.chandu at iiitb.net
Tue May 25 07:14:02 CDT 2010
We are facing issue when we are trying to send event Events.Event.OPEN_APP
to the application event channel using an external application. We are
getting AccessGrid.GroupMsgDefines.NotConnectedException at
vec.send(….)when we run the following code. Please help us to understand
what is the root cause.
------------------- Code snippet BEGIN-------------------------
clientProfile = GetClientProfile()
name = *'Shared Browser'*
description = *'Started by XXXX'*
uri = *'
https://localhost:8000/Venues/c0a801020ff01df9cc9ce0badeb550b5/apps/0a44b942054c2ab5eac872caed001a03
oid = *'0a44b942054c2ab5eac872caed001a03'*
mimetype=*'application/x-ag-shared-browser'*
startable = *'1'*
appDesc = ApplicationDescription(oid, name, description, uri, mimetype,
startable)
verb=*'Open'*
cmd=None
data = ApplicationCmdDescription(appDesc, verb, cmd, clientProfile)
location = (*'localhost'*, 8002) # venue server running on same machine
conid = *'0a44b9421ebc2e3de5fe168afc2c1b44'* # getting connection id
of the client from the venue state
chnl = *‘c0a801020ff01df9cc9ce0badeb550b5’ *# hardcoded after looking
into logs
groupMsgClientClassList = GetFormatList()
*vec = SecureVenueEventClient(**location=location, privateId=conid,
channel=chnl) *
* vec.Send(Events.Event.OPEN_APP, data)*
vec.Start()
reactor.run()
------------------- Code snippet END-------------------------
Thanks for the help.
Chandu
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20100525/f3855cc1/attachment.htm>
