[AG-DEV] UCL common lib rtp_recv & frame timing
Andrew Ford
andrew.ford at rit.edu
Thu Jul 29 11:52:09 CDT 2010
After some further investigating (mostly timing rtp_recv, rtp_recv_data and
process_rtp) it seems like there is some correlation between the time
udp_select takes and the frame delay (though it's not completely
consistent). Confusingly, if I set the timeout to 0 rtp_recv predictably
takes very little time but the frame delay is still there, and I couldn't
find any other places where the time went (path seems to be rtp_recv ->
rtp_recv_data -> process_rtp -> callback). Is anyone familiar with
performance issues related to select(), or how any other applications do
fast UDP reading?
--Andrew
2010/7/28 Andrew Ford <andrew.ford at rit.edu>
> Hi Rhys,
> I've tried calling rtp_recv once with both 10ms and 1ms timeout times (as
> well as no timeout at all) and it looks like it doesn't make a difference. I
> also tried changing the system UDP buffer sizes to see if that had any
> effect, but it doesn't seem to.
> --Andrew
> 2010/7/27 Rhys Hawkins <rhys.hawkins at anu.edu.au>
> On Tue, 27 Jul 2010 14:12:37 -0400
>> Andrew Ford <andrew.ford at rit.edu> wrote:
>> > timeout.tv_sec = 0;
>> > timeout.tv_usec = 10000;
>> > for (int i = 0; i < 1000 && rtp_recv(session, &timeout, _timestamp); i
>> > timeout.tv_sec = 0;
>> > timeout.tv_usec = 10;
>> Hi Andrew,
>> All that code is doing is a crude version of:
>> while (elapsed_time < 10ms) {
>> process incoming packets
>> You could try and replace the for loop with just one call to the rtp_recv
>> function, ie:
>> timeout.tv_sec = 0;
>> and see if that fixes your problem.
>> The code above was to handle an issue with DV decoding in that decoding an
>> entire frame of DV took a certain length of time and during that time the
>> UDP buffer (kernel side) could overflow causing loss of data. I don't
>> think
>> it should be the cause of your problems, but things are pretty foggy that
>> far back in time so it may have other ramifications I've forgotten about.
>> Cheers,
>> Rhys
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20100729/25c68deb/attachment.htm>
