[AG-DEV] UCL common lib rtp_recv & frame timing
Rhys Hawkins
rhys.hawkins at anu.edu.au
Tue Jul 27 19:17:31 CDT 2010
On Tue, 27 Jul 2010 14:12:37 -0400
Andrew Ford <andrew.ford at rit.edu> wrote:
> timeout.tv_sec = 0;
> timeout.tv_usec = 10000;
> for (int i = 0; i < 1000 && rtp_recv(session, &timeout, _timestamp); i ++) {
> timeout.tv_sec = 0;
> timeout.tv_usec = 10;
Hi Andrew,
All that code is doing is a crude version of:
while (elapsed_time < 10ms) {
process incoming packets
You could try and replace the for loop with just one call to the rtp_recv
function, ie:
timeout.tv_sec = 0;
and see if that fixes your problem.
The code above was to handle an issue with DV decoding in that decoding an
entire frame of DV took a certain length of time and during that time the
UDP buffer (kernel side) could overflow causing loss of data. I don't think
it should be the cause of your problems, but things are pretty foggy that
far back in time so it may have other ramifications I've forgotten about.
Cheers,
Rhys
