[AG-DEV] Cert issues on Fedora 12
Christoph Willing
c.willing at uq.edu.au
Thu Feb 25 07:19:24 CST 2010
On 25/02/2010, at 9:49 PM, Jason Bell wrote:
> G'day Chris and Tom
> Thanks for the quick feedback...
> Okay, I am not sure what I have done, but nothing seems to be
> working...
> So, not knowing how to "add the new CA certs" as provided in https://lists.mcs.anl.gov/mailman/htdig/ag-tech/2010-January/021336.html
If you click on each of the links to .obj files there, you'll see that
one is mainly gibberish and the other has a bit of readable text. Save
the gibberish one locally as 45cc9e80.Jan2010.0 and save the other as
45cc9e80.Jan2010.0.signing_policy. Copy these into the /etc/
AccessGrid3/Config/CAcertificates/ directory. Now if you run
certmgr3.py (plain certmgr on Fedora) with the -C option, it will
start up in CA mode (there'll be a "CA>" prompt). If you enter the
command "list" at the prompt, you should see 3 CA's listed there i.e.
the AG Developers CA will be missing. Now enter "import
45cc9e80.Jan2010.0" (presuming you're in the right directory to do
that). You should now see 4 CA's listed after running the list command
again. If so, all is OK - type "quit" to exit.
There may be a few wrinkles in those instructions - taken from
memory ...
chris
> I thought I would try using the CertificateManager or
> CertificateRequestTool programs, but I get the following error
> messages when executing these programs from a Terminal:
> [ace at linux Desktop]$ CertificateManager
> /usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/
> ClientProfile.py:22: DeprecationWarning: the md5 module is
> deprecated; use hashlib instead
> import md5
> /usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/
> ProxyGen.py:19: DeprecationWarning: The popen2 module is
> deprecated. Use the subprocess module.
> import popen2
> Traceback (most recent call last):
> File "/usr/bin/CertificateManager", line 64, in <module>
> main()
> File "/usr/bin/CertificateManager", line 52, in main
> certMgr = app.GetCertificateManager()
> <SNIP>
> File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/
> Security/CertificateRepository.py", line 1297, in GetMetadata
> return self.cert.GetMetadata(k)
> Security/CertificateRepository.py", line 1590, in GetMetadata
> hashkey = self._GetMetadataKey(key)
> Security/CertificateRepository.py", line 1579, in _GetMetadataKey
> self.GetIssuerSerialHash(),
> Security/CertificateRepository.py", line 1504, in GetIssuerSerialHash
> serial = struct.pack("l", self.cert.get_serial_number())
> struct.error: long too large to convert to int
> So I thought I would copy the files to /etc/AccessGrid3/Config/
> CAcertificates, but neither the VenueClient nor the about cert
> programs mentioned above works.
> I even tried doing a yum remove AccessGrid and then a yum install
> AccessGrid.
> Maybe I am doing something wrong, any advice would be appreciated.
> Should I completely remove the /etc/AccessGrid3 directory and start
> again?
> Thanks in advance,
> Jason.
> -----Original Message-----
> From: Christoph Willing [mailto:c.willing at uq.edu.au]
> Sent: Thursday, 25 February 2010 3:07 PM
> To: Jason Bell
> Cc: ag-dev
> Subject: Re: [AG-DEV] Cert issues on Fedora 12
> On 25/02/2010, at 2:48 PM, Jason Bell wrote:
>> G'day All
>> Just wondering if any has installed Fedora 12 and the Access Grid
>> software recently.
>> I have tried to install the AG software at home and got some error
>> messages which appears to relate to the certificate.
>> Just wondering if anyone has seen this.
>> Thanks,
>> Jason.
>> PS, this is the error message I get:
> [snip]
>> VenueClientUI.py", line 533, in __SetMenubar
>> mgr = app.GetCertificateManager()
>> Toolkit.py", line 473, in GetCertificateManager
>> self._certificateManager.InitEnvironment()
>> Security/CertificateManager.py", line 564, in InitEnvironment
>> self._InitializeCADir()
>> Security/CertificateManager.py", line 645, in _InitializeCADir
>> for c in self.GetCACerts():
>> Security/CertificateManager.py", line 768, in GetCACerts
>> caCerts = self.certRepo.FindCertificatesWithMetadata(mdkey, mdval)
>> Security/CertificateRepository.py", line 1201, in
>> return list(self.FindCertificates(lambda c: c.GetMetadata(mdkey)
>> == mdvalue))
>> Security/CertificateRepository.py", line 1191, in FindCertificates
>> if pred(cert):
>> Security/CertificateRepository.py", line 1201, in <lambda>
>> == mdvalue))
> Looks like a repeat of this one:
> You need to add the new CA certs attached there to /etc/AccessGrid3/
> chris
>> File "/usr/bin/VenueClient", line 173, in <module>
>> main()
>> File "/usr/bin/VenueClient", line 150, in main
>> vcui = VenueClientUI(vc, vcc, app)
>> VenueClientUI.py", line 237, in __init__
>> self.__BuildUI(app)
>> VenueClientUI.py", line 980, in __BuildUI
>> self.__SetMenubar(app)
>> VenueClientUI.py", line 538, in __SetMenubar
>> self.cmui = CertificateManagerWXGUI.CertificateManagerWXGUI(mgr)
>> UnboundLocalError: local variable 'mgr' referenced before assignment
>> Jason Bell, B.I.T. (Honours)
>> Research Systems Support Officer
>> Information Technology Division
>> CQ University Australia
>> Australian Research Collaboration Service
>> http://www.arcs.org.au/
>> E-mail : j.bell at cqu.edu.au
>> jason.bell at arcs.org.au
>> Work : +61 7 4930 9229
>> Mobile : 0409 630897
>> Postal : Building 19
>> Central Queensland University
>> Bruce Highway
>> Rockhampton, Queensland, Australia, 4702
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
