[AG-DEV] Transcoding DVTS streams?
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Fri Nov 27 03:05:18 CST 2009
I will be relying on FFMPEG. I usually write my own packetizers and depacketizers when they are not available. The whole thing will be in Java (other than the native code calls).
Andrew :-)
Andrew G D Rowley
Senior Development Officer
Research Computing Services
The University of Manchester
Devonshire House, Oxford Road
Manchester, M13 9PL
t : +44 (0) 161 275 0685
e : Andrew.Rowley at manchester.ac.uk
w : www.manchester.ac.uk/researchcomputing
From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On Behalf Of Andrew Ford
Sent: 25 November 2009 20:00
To: Piers O'Hanlon; Andrew.Rowley at manchester.ac.uk
Cc: wg-multicast at internet2.edu; ag-dev at mcs.anl.gov; asaeda at sfc.wide.ad.jp
Subject: Re: [AG-DEV] Transcoding DVTS streams?
To clarify, like others said, ffmpeg can decode the DV codec in general (ie, you can plug a camera in and view it) but it apparently can't depacketize DVTS, since when you try to receive a DVTS stream it just looks like noise. VLC can do neither as far as I can tell.
Piers - thanks for the info, I'll give gstreamer a try.
Andrew - what are you using as the backend for this transcoding tool? Is it all custom-written or do you rely on libraries like ffmpeg?
--Andrew
2009/11/25 Piers O'Hanlon <p.ohanlon at cs.ucl.ac.uk>
Hi Andrew,
Another way you could probably knock something up quickly is using
gstreamer - v0.10 contains a DV de/payloader:
%gst-inspect-0.10 | grep "dv:"
typefindfunctions: video/x-dv: dif, dv
dv: dvdemux: DV system stream demuxer
dv: dvdec: DV video decoder
ffmpeg: ffdemux_dv: FFmpeg DV video format demuxer
ffmpeg: ffmux_dv: FFmpeg DV video format muxer
You could play with creating a pipeline using gst-launch-0.10 to do
what you want or you can write a small app in Python or C++ using the
gstreamer libraries.
Piers
2009/11/24 Andrew Ford <andrew.ford at rit.edu>:
> Hi,
> Has anyone attempted or found a way to transcode a DVTS stream directly off
> of receiving it via multicast? My goal is to be able to transcode DVTS
> streams to different formats and resend them as Access Grid-based or
> web-based streams. So far, it looks like the only way to do it would be to
> modify xdvshow or one of the other DVTS apps to hook together with ffmpeg
> for transcoding & ffserver for streaming, since as far as I can tell, apps
> like ffmpeg or VLC can't receive DVTS by themselves. Before I go spending a
> bunch of time on that I want to make sure this hasn't already been done some
> other way.
> Thanks,
> --Andrew
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20091127/3a81feef/attachment.htm>
