[AG-DEV] Transcoding DVTS streams?
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Wed Nov 25 05:20:32 CST 2009
Hi Andrew,
Another way you could probably knock something up quickly is using
gstreamer - v0.10 contains a DV de/payloader:
%gst-inspect-0.10 | grep "dv:"
typefindfunctions: video/x-dv: dif, dv
dv: dvdemux: DV system stream demuxer
dv: dvdec: DV video decoder
ffmpeg: ffdemux_dv: FFmpeg DV video format demuxer
ffmpeg: ffmux_dv: FFmpeg DV video format muxer
You could play with creating a pipeline using gst-launch-0.10 to do
what you want or you can write a small app in Python or C++ using the
gstreamer libraries.
Piers
2009/11/24 Andrew Ford <andrew.ford at rit.edu>:
> Hi,
> Has anyone attempted or found a way to transcode a DVTS stream directly off
> of receiving it via multicast? My goal is to be able to transcode DVTS
> streams to different formats and resend them as Access Grid-based or
> web-based streams. So far, it looks like the only way to do it would be to
> modify xdvshow or one of the other DVTS apps to hook together with ffmpeg
> for transcoding & ffserver for streaming, since as far as I can tell, apps
> like ffmpeg or VLC can't receive DVTS by themselves. Before I go spending a
> bunch of time on that I want to make sure this hasn't already been done some
> other way.
> Thanks,
> --Andrew
