[AG-DEV] New Installs - Multiple Issues
Todd ZImmerman
todd.zimmerman at ubc.ca
Fri Sep 26 18:10:36 CDT 2008
On Tue, 2008-09-23 at 22:36 +1000, Christoph Willing wrote:
> Actually, I think there's a better workaround (no immediate code
> changes). Check the multicast entry in your ~/.AccessGrid3/Config/
> preferences file. It will probably be set to False if you're setup to
> use a bridge by default. Change this to a 0 (zero). Similarly, change
> it to a 1 if it was set to True.
Worked like a charm - thx.
Also, regarding the bridge issue - it appears it was a local vlan issue
although I'm still not clear why I was picking up bridges from AP but
not Argonne.
Thanks for the help.
Todd
Collaboration & Visualization Specialist
UBC Okanagan - web.ubc.ca
WestGrid - www.westgrid.ca
Ph. 250-807-9979
Todd Zimmerman - todd.zimmerman at ubc.ca
