[AG-DEV] AGTk Development : Cannot build UCL Common Library
Thomas D. Uram
turam at mcs.anl.gov
Thu Sep 11 17:48:22 CDT 2008
Hi Thibault:
You don't need to build everything from source to do what you're trying
to do. Use the Access Grid installer to get all the dependencies in
place. Then you can check out the Access Grid module from subversion,
and set up the environment, according to the instructions on this page:
http://www.accessgrid.org/developer
These instructions are fairly new, so if you run into problems with
them, please let us know so we can update them. If you'd like to update
them yourself, let me know and I'll give you the appropriate permissions
for the site.
Also, I'm curious to know what else went wrong when you were trying to
build from source, so we can get that fixed. Ideally, building from
source would be trivial.
Tom Uram
On 9/11/08 5:29 PM, Thibault Daoulas wrote:
> Oh I'm sorry, just forgot to mention that I am on Windows XP and
> compiling with MinGW-Msys...
> -----Original Message-----
> From: Thibault Daoulas
> Sent: Friday, 12 September 2008 9:37 a.m.
> To: Thibault Daoulas; ag-dev at mcs.anl.gov
> Subject: RE: [AG-DEV] AGTk Development : Cannot build UCL Common Library
> Obviously it was my version of SWIG that was too old. Anyway, I still
> have a lot of problems building the UCL Common library, but keep on
> struggling with this, for 2 weeks now :(, so if anyone has already
> experienced concerns with it, please tell me about some subtle, or
> obvious things that I may not have seen on the community or other
> building webpages.
> I also wanted to make sure that I actually really need to build
> everything from sources for what I intend to develop on the AccessGrid
> (improvement of the GUI, and integration of computer vision tools).
> Thanks a lot for your help,
> Thibault.
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On
> Behalf Of Thibault Daoulas
> Sent: Tuesday, 9 September 2008 11:58 a.m.
> To: ag-dev at mcs.anl.gov
> Subject: [AG-DEV] AGTk Development : Cannot build UCL Common Library
> Hi,
> I am running the AGTk from source, but vic and rat do not work, and I
> guess it is because I could not build the UCL Common Library, from the
> dependencies specified here :
> http://www.accessgrid.org/developer/dependencies/3.1
> When I run make in the corresponding folder I get this message :
> swig -I../../src -python -c++ -o common_wrap.cpp common.i
> (3): Error: Unable to find 'python.swg'
> common.i(17): Error: Unable to find 'typemaps.i'
> make: *** [common_wrap.o] Error 1
> And when I try to build from MS Visual Studio 2005 solution file I get
> this message :
> ------ Build started: Project: _common, Configuration: Release Win32
> Regenerate SWIG wrapper.
> swig error : Unrecognized option
> Files\AGDependencies\common\common\examples\_common\\common_wrap.cpp
> swig error : Unrecognized option c:\Program
> Use 'swig -help' for available options.
> Project : error PRJ0019: A tool returned an error code from "Regenerate
> SWIG wrapper."
> Do you have any idea of what could be wrong?
> Thanks,
> Thibault.
