[AG-DEV] Windows Node services bug!
Douglas Kosovic
douglask at itee.uq.edu.au
Thu Oct 30 02:56:40 CDT 2008
Hi Jason
> I have come across a bug in which I was wondering if a fix has already
> been submitted into SVN?
> The bug is on a windows XP machine, in which none of the media tools
> would start. (Though the tools could be started manually from the
> Command Line).
Could you try modifying win32\ProcessManager.py and add the following
code:
if command.find(" ") != -1:
# If there are spaces, quote the command
command = '"' + command + '"
just before:
cmdline = command
for arg in arglist:
arg = str(arg)
if arg.find(" ") != -1:
# If there are spaces, quote the arg
arg = '"' + arg + '"'
cmdline += " " + arg
if it works, I could SVN check-in the changes.
Doug
