[AG-DEV] AG3.2b Issues/Questions
Thomas D. Uram
turam at mcs.anl.gov
Wed Nov 19 14:18:24 CST 2008
Todd:
I'll look at the log file for the first issue.
Regarding the second issue, the services are now run inline in the
VenueClient process, to speed up messaging between those components by
avoid sockets between them. Because of this, they don't generate
separate log files, but instead log to VenueClient.log. I can see that
this is undesirable, so a bug/enhancement request is probably warranted
in this case.
Tom
On 11/19/08 11:36 AM, Zimmerman, Todd wrote:
> Version AG3.2b
> Platform Fedora 9 - KDE4
> I'm having a couple of issues with AG3.2b and wanted to send out a note
> for clarifications/advice before filing a bug (it may be a configuration
> issue on my end).
> To launch AG I've been using a panel icon created in KDE4. I haven't
> been launching in debug mode typically - but am starting to.
> First issue, about 1 in 10 or so times the launch fails silently.
> Splash appears, everything seems to be going fine - then nothing. No
> Venueclient appears. Second and subsequent attempts succeed.
> VenueClient.log (attached) is quite short - ending with a line
> indicating that the NodeService is starting.
> Second issue is, there doesn't seem to be any logs being created other
> than the VenueClient.log. AudioService, VideoService,
> VideoProducerService either don't exist or haven't been touched in
> months. The dates seem to coincide w/ AG3.2b upgrade - is this true??
> Does the beta specifically stop writing to the additional logs or is
> this a bug?
> Wanted to see if there was any advice on how I could narrow down these
> issues before submitting bugs.
> Cheers,
> Todd
