[AG-DEV] Trying to understand the debug option
Eric Olson
eolson at mcs.anl.gov
Fri May 9 15:45:23 CDT 2008
Mike,
It looks like we disable that by default to prevent console windows from
popping up, but here's how to override it:
In AccessGrid/Platform/win32/Platform.py
(which is usually in C:\Python24\Lib\site-packages)
about line 70 has this:
win32con.NORMAL_PRIORITY_CLASS|win32con.CREATE_NO_WINDOW,
Removing the last part of the line lets the console pop up. The
resulting line looks like this:
win32con.NORMAL_PRIORITY_CLASS,
I also added "--debug" to the shared browser line in the
ApplicationDatabase (I'm pasting this because when I put the -d at the
end of the line, it gave me an error):
C:\Python24\python.exe SharedBrowser.py --debug -a %(appUrl)s
I did try it with the SharedBrowser this time and saw log output.
Eric
Michael Miller wrote:
> Eric,
> Here's what I have in the appdatabase:
> [application/x-ag-shared-browser]
> 8d8ede761bf01e4b7d0fdd82ea2ce39e = C:\Python24\python.exe SharedBrowser.py -d -a %(appUrl)s
> and the sharedbrowser window doesn't show. No log file is created so I have no idea what's wrong.
> Here's the output from the venueclient console:
> 05/09/08 14:21:13 16252 VenueClient venueclientui.py:4649 INFO Got commands:
> (application/x-ag-shared-browser) {'Open': 'C:\\Python24\\python.exe SharedBrowser
> .py -d -a %(appUrl)s'}
> 05/09/08 14:21:16 16252 VenueClientController venueclientcontroller.py:1542 IN
> FO StartCmd starting command: C:\Python24\python.exe SharedBrowser.py -d -a https
> ://141.142.224.40:8000/Venues/000000fe456540d8008d008e0040000bfa6/apps/8d8ee0287ab
> c2e34b5faa4dca062dfdd
> 05/09/08 14:21:16 16252 ProcessManager processmanager.py:62 DEBUG Creating pro
> cess: C:\Python24\python.exe SharedBrowser.py -d -a https://141.142.224.40:8000/Ve
> nues/000000fe456540d8008d008e0040000bfa6/apps/8d8ee0287abc2e34b5faa4dca062dfdd
> 05/09/08 14:21:16 16252 ProcessManager processmanager.py:75 DEBUG Create proce
> ss returns: (<PyHANDLE:1840>, <PyHANDLE:2028>, 17332, 12536)
> Does this look correct?
> thanks
> myk
> From: "Eric Olson" <eolson at mcs.anl.gov>
> To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
> Cc: "AG-DEV" <ag-dev at mcs.anl.gov>
> Sent: Friday, May 9, 2008 12:09:57 PM GMT -06:00 US/Canada Central
> Subject: Re: [AG-DEV] Trying to understand the debug option
> Hi Mike,
> The --debug option only affects how much output is printed.
> It's already available if you're doing this:
> app = Toolkit.CmdlineApplication.instance()
> app.Initialize("BasicApp")
> The first thing you want is to open the output in a shell window --
> probably on MS Windows.
> That happens for a python program on windows when it's started with
> python.exe instead of pythonw.exe.
> For shared applications, there are two ways you could change this:
> A)
> The command used to open your shared app is stored in the
> ApplicationDatabase: (likely here: C:\Documents and
> Settings\USERNAME\Application Data\AccessGrid3\Config\ApplicationDatabase)
> You can open it and change the line that opens your shared app from
> "pythonw.exe" to "python.exe". You can also add the "-d" in there if
> you want.
> B)
> Instead of manually editing the file, you could alternatively reregister
> your shared app using "python.exe agpm.py ..." to have the same effect.
> Whichever you run agpm with, pythonw.exe or python.exe, will be the cmd
> stored in the ApplicationDatabase. If you're double-clicking on an
> agpkg file to install it, pythonw.exe is the one being used.
> Eric
>> I'd like to add a -d --debug option to my sharedapp. But in looking at VenueClient3.py and VenueServer3.py, I see where the "port" or "personalNode" options are handled, but the "debug" option isn't handled there. Where can I find an example of how the "debug" option is incorporated into a script to open up a shell dialog and show the script output?
>> thanks
>> myk
