[AG-DEV] Identity certificates
Thomas D. Uram
turam at mcs.anl.gov
Fri Mar 14 12:16:48 CDT 2008
Hi Luis:
The problem is with the AG node configuration. By default, the
VenueClient starts with a VideoConsumerService, which is configured to
only receive video, not send it. You should do this:
- In tools, select ConfigureNodeServices...
- Select the VideoConsumerService and remove it
- Select Services, then Add, then VideoService. You'll be prompted to
select a capture device.
- Save this configuration as the default
- Enter a Venue. Vic will start, transmitting from the camera you
selected, and displaying video streams from others in the venue.
Tom
On 3/14/08 11:22 AM, Luis Galárraga wrote:
> Our problem is that it seems VIC does not recognize the connected
> webcams. We did the test in four computers: two laptops with Ubuntu
> 7.10, one laptop and a PC with Windows XP. In all cases cameras were
> tested and recognized by other applications: Cheese, aMSN and VLC in
> Ubuntu Linux, VLC and Windows Messenger in Windows. VLC did not
> recognize it automatically in Linux so we had to provide the name of
> the device file.
> Then we ran the Venue Client and entered a venue. VIC and RAT started
> running as expected and audio could be transmitted without any
> problem, VIC only showed a "Waiting for video" message. When pressing
> the Menu button in VIC window, we realized that "Transmit button" was
> disabled in all computers. I read that happens when video capture
> hardware is not properly configured. We are looking for a way of
> telling vic the path to the device file of the camera, but no success
> until now. By the way, these are the webcams we used: Creative VF0050,
> Genius VideoCam Messenger and VGA Matrix Webcam.
> We also did another tests transmitting multicast camera streams with
> vlc with relative success (when transmitting from Windows, there were
> several problems, VLC frequently froze; in Linux complete happiness)
> In relation with the add-on services you mentioned, those are good
> news for us, as we want to provide both Windows and Linux users a
> simple way to participate in our webinars. Another question: Where
> can we found the most updated vic and rat documentation?
> Thanks in advance,
> Luis
> 2008/3/14, Thomas D. Uram <turam at mcs.anl.gov <mailto:turam at mcs.anl.gov>>:
> Luis:
> The video capture machine has, in the past, often run Linux, which
> is why you got that impression from looking at older documentation.
> In AG3, vic can use USB cameras, firewire cameras, and dedicated
> capture cards with either a VFW (older) or WDM/DirectShow (newer)
> driver. You should be having success in either of these cases.
> If you're not, we need to look into the cause a little deeper.
> Provide more details of the problems you ran into, and your
> configuration, and I/we can help.
> There are add-on services for transmitting/receiving video using
> VLC (http://netmedia.gist.ac.kr/agdv/download.html). These have
> so far only been made available on Windows, but it would be
> trivial to make them also work under Linux (with VLC; DVTS would
> be more difficult).
> Tom
> On 3/13/08 10:07 AM, Luis Galárraga wrote:
>> Thanks a lot for your help Tom. I have two additional questions,
>> but they related to audio and video transmision. As I mentioned,
>> our objective are single node users which should have just a
>> webcam and a microphone to participate in a webinar. People here
>> in ESPOL (colleagues but not members of this project), have
>> successfully tested AG in node configuration, but when we tried
>> with a single computer, we could not transmit video. Worried
>> about this fact, I read all documentation about VIC and
>> understood that it requires a video capture card (our colleagues
>> had one) for transmitting video. Reviews and documentation about
>> node configurations indicate that the video capture computer
>> should be a Linux machine with a video capture card and that only
>> in Windows it is possible do it with a usb webcam or a firewire
>> camera (no video card needed). Our tests were in both platforms
>> without success. Do Linux users need a frame grabber for transmit
>> video? Is it possible to use another tool like VLC for
>> transmitting video? We had successful results transmitting
>> multicast video streams from a webcam using VLC in Ubuntu Linux
>> and Windows XP. In addition, we found a way of redirecting raw
>> video to another application instead of showing it with VLC.
>> Thanks again.
>> Luis,
>> 2008/3/13, Thomas D. Uram <turam at mcs.anl.gov
>> Hi Luis:
>> There are a few things you need to know in this regard:
>> - By default, AG3 venues do not require that clients have a
>> certificate
>> to enter. Venues can be optionally configured to require a
>> certificate,
>> in which case the user must present a certificate that
>> satisfies the
>> access controls on the venue.
>> - You can run your own CA and issue your own
>> certificates. In that
>> case, you'll need to make sure your clients have both your CA
>> certificate and their personal certificate.
>> Otherwise, this is general PKI. If you have other questions,
>> don't
>> hesitate to ask.
>> Tom
>> On 3/6/08 3:41 PM, Luis Galárraga wrote:
>> > Greetings:
>> > I am part of project for developing a webinar
>> infraestructure based on
>> > Access Grid. After a long discussion in which suggestions in
>> this
>> > mailing list were strongly considered, we have decided to
>> implement a
>> > simple client for venues (in servers 3.x) using Java Web
>> Start Apps.
>> > As you can see, there are many things to do, and developers have
>> > started by making tests with the soap interfaces in the our
>> AG server,
>> > however they are not clear about the concepts behind the
>> > authentication process. We know AG uses digital certificates for
>> > everything: users and services and those certificates are
>> generated by
>> > AG developers (after a process request). Can our developer team
>> > generate certificates signed by us or it is required your sign?
>> > Several people in our university will probably use the
>> system so we
>> > would like to have the privilege to generate the
>> certificates. Could
>> > someone explain us in a better way, the technical issues behind
>> > authentication based on certificates (= how you implemented
>> it)?. I
>> > hope you can help us.
>> > Thanks in advance,
>> > Regards,
>> > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080314/d5982ee6/attachment.htm>
