[AG-DEV] About Text Service
lester leong
ihpcrcw at gmail.com
Fri Jun 13 09:02:06 CDT 2008
Hi All,
Like Luis, I managed to set up Jabber Server ( Jabberd-1.4.4) and edited the
VenueServer.cfg file. However, when I launch the Venue Client and join a
venue, I get the following error:
06/13/2008 09:52:40 PM -1279411280 VenueClient VenueClient.py:1118 ERROR
EnterVenue.__StartJabber failed
Traceback (most recent call last):
File
"/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/VenueClient.py",
line 1116, in DoPostEnter
self.__StartJabber(self.textLocation)
File
line 1203, in __StartJabber
self.jabber.Connect(jabberHost, jabberPort)
File
"/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Jabber/JabberClient.py",
line 39, in Connect
self._stream = stream.JabberClientStream(host, port=port, use_ssl=True)
File "/usr/lib/python2.4/site-packages/gov/lbl/dsd/bajjer/stream.py", line
154, in __init__
self.open(host, port, use_ssl)
110, in open
self._conn = io.Connection(host, port, use_ssl)
File "/usr/lib/python2.4/site-packages/gov/lbl/dsd/bajjer/io.py", line
106, in __init__
self._sock.send(self._header(to_=host))
File "/usr/lib/python2.4/site-packages/gov/lbl/dsd/bajjer/ssl.py", line
44, in send
bytes = self._sock.send(data)
112, in send
bytes = self._ssl.send(data)
Error: [('SSL routines', 'SSL23_GET_SERVER_HELLO', 'unknown protocol')]
When I try to key in some text in the textbox, I get an error "You have to
be connected to a venue to send a text message". This is despite already
connected to a venue.
Any ideas?
Cheers
lester
On Fri, Apr 18, 2008 at 7:08 AM, Luis Galárraga <lgalarra at fiec.espol.edu.ec>
wrote:
> Hi,
> At first I thought AG included an embedded jabber service,
> now I understand it uses a remote and configurable one. We would like to set up ours so I have several questions:
> - According to my VenueServer.cfg file, I am using xxxx server, so I
> suppose you synchronize your Jabber server database when a certificate
> request is accepted. Am I right?
> Are jabber users persistent or are they deleted once disconnected from venue? I could see a Register method in JabberClient.py.
> - Which Jabber server do you recommend us? Developers have read about OpenFire (
> http://www.igniterealtime.org/projects/openfire/index.jsp
> ) as it is written in Java and includes documented libraries for developing Jabber clients easily.
> - When you authenticate in Jabber service, which password is it used? I
> know profiles does not include any password? How do you exactly
> authenticate?
> I would appreciate your answers. Thanks in advance.
> Luis,
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080613/789fa571/attachment.htm>
