[AG-DEV] SendEvent of SharedAppClient doesn't work
Florian Birnthaler
florian.birnthaler at canterbury.ac.nz
Thu Jul 3 19:45:37 CDT 2008
Hello,
I have a strange problem with the SendEvent-method of the
SharedAppClient.
If I send a string or a number it works without a problem. The
number/string is perfectly received by the method that I registered as
the event handler.
But if I send a tuple or a list I receive a dictionary with the keys
being some weird strings and their values being the elements of the
tuple/list.
Here is an example of some debug messages:
DEBUG: sending SetView event: ('testString1', 'testString2')
DEBUG: SetView event received: {'Eoa8a390': u'testString1', 'Eoa8a3b8':
u'testString2'}
I don't chance the events in any way, after I send them. There seems to
be something wrong with the serialized data that is sent over to the
event channel. I used the Python debugger to get deeper into the
SendEvent-call and found out that this SOAP envelope was created:
<SOAP-ENV:Envelope
xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:ZSI="http://www.zolera.com/schemas/ZSI/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><SOAP-ENV:Header><
/SOAP-ENV:Header><SOAP-ENV:Body><Eo33f9a80
xmlns:ns1="http://www.accessgrid.org/v3.0"
xsi:type="ns1:EventDescription"><ns1:channelId
xsi:type="xsd:string">82664eb22bc448ef7711328383d23793</ns1:channelId><n
s1:senderId
xsi:type="xsd:string">82664eb22bc44a6852b8726be95ce316</ns1:senderId><ns
1:data><Eoaa7f98 xsi:type="xsd:string">testString1</Eoaa7f98><Eoaa7fc0
xsi:type="xsd:string">testString2</Eoaa7fc0></ns1:data><ns1:eventType
xsi:type="xsd:string">SetView</ns1:eventType></Eo33f9a80></SOAP-ENV:Body
></SOAP-ENV:Envelope>
Here you can already see those strange numbers. But I don't know what
they mean or how to get rid of them. Because in my event handler method
T just want to receive the original tuple or list. I searched for a
solution in the web, but unfortunately I didn't find anything.
Does someone have an idea how to fix this?
Cheers,
Florian
