[AG-DEV] Web client for AG
Luis Galárraga
lgalarra at fiec.espol.edu.ec
Thu Feb 28 12:26:27 CST 2008
That solution is really interesting as I can see, however according to the
exposed ideas, our time and resources constraints make it a risky option. I
have another question. The idea of developing a web client is to make AG
client more ubiquitous and accessible to everyone. Do you use any kind of
bridging for cases in which the client does not have access to a multicast
network??.
2008/2/28, Andrew Rowley <Andrew.Rowley at manchester.ac.uk>:
> Hi,
> We found that to enable the client to launch external processes, you need
> something in addition to the web browser. We decided to use java for this –
> in both applet and web application forms (an applet is used to talk between
> the web browser and the web start). The web start application does all the
> backend work, and the web browser is then used for the gui front end. The
> communication to the web application side (which then communicates to the
> AGTk server) is via AJAX – we have designed an XMLRPC queuing system for
> this. This queue is also used to receive events at the browser gui side
> (such as a user joining the session).
> One of the main issues we came across was coping with the user refreshing
> the page. This is an issue for us because we are developing in a portlet
> environment. Without this, we could have just said that the page should
> never be refreshed I guess.
> Andrew J
> Andrew G D Rowley
> Senior Development Officer
> Research Computing Services
> The University of Manchester
> Kilburn Building, Oxford Road
> Manchester, M13 9PL
> t : +44 (0) 161 275 0685
> e : Andrew.Rowley at manchester.ac.uk
> w : www.manchester.ac.uk/researchcomputing
> *From:* owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] *On
> Behalf Of *Luis Galárraga
> *Sent:* 27 February 2008 23:09
> *To:* Thomas D. Uram
> *Cc:* ag-dev at mcs.anl.gov; alejandro moreno; Alejandro Moreno; Ing.
> Verónica Macías; Marisol Villacrés
> *Subject:* Re: [AG-DEV] Web client for AG
> Thomas,
> Thanks a lot for your help. I feel there is light at the end of the
> tunnel!!! However, as you can imagine, we have important time constraints. A
> web client is one of our possibilities (my favorite one) and looks a hard
> matter. One important point for us, is portability of the client, that is
> why we considered the web approach. Other options are a lightweight client
> application written in Python, an applet or a Java Web Start application .
> To start, we would just implement audio and video transmission, then we
> could extend the application to support all AG functionalities. I would like
> to know your opinion about these options.
> And finally, would you recommend us to use AGTk 3.0? How feasible is it
> considering the available resources until now??. Thanks again!!!
> Regards,
> Luis Galárraga
> 2008/2/27, Thomas D. Uram <turam at mcs.anl.gov>:
> Hi Luis:
> I'm the tech lead at Argonne for the Access Grid project. I'm very
> interested in the work you are proposing, and have some comments:
> - The API documentation has not, as you've noticed, been updated for
> AG3. This needs to be done. I could generate documentation of the web
> services interfaces fairly easily, which is necessary since there have
> been some changes from AG2.
> - There are a couple ways to approach a web-based client. One is to
> build an "adapter" between the VenueServer and the web browser; this
> adapter would accept HTTP from the user, make SOAP calls to the AG
> VenueServer, and return HTTP responses to the user. I wrote a basic
> example of this here: http://www.accessgrid.org/node/971 . Another,
> possibly better solution, would be to make the SOAP calls at the client
> using a JavaScript SOAP implementation. Both of these leave open the
> question of how to handle the audio and video.
> It's a priority for us to update the documentation, but I can't promise
> when that will be done. If we can help answer questions in the
> meantime, please don't hesitate to ask either here on the ag-dev list,
> or by emailing me directly.
> Thanks,
> Tom Uram
> On 2/26/08 3:06 PM, Luis Galárraga wrote:
> > Greetings:
> > I am really interested in Access Grid Development as I take part in a
> > small community who is developing a software for videoconferencing
> > based on AGTk. At the moment, we are in the design phase and some of
> > us are analyzing the possibility of writing a web client for Venues.
> > Of course, there are certain constraints: we only need to use AG in
> > the easiest configuration, personal node. We would like to know your
> > opinions about this decision. How difficult and feasible is that?. (We
> > have discuss some technical facts and consequences). It is obvious
> > that the advantages of doing that are numerous.
> > Thanks in advance for your contributions to this topic.
> > Regards,
> > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080228/2466a218/attachment.htm>
