[AG-DEV] Web client for AG
Robert Olson
olson at mcs.anl.gov
Thu Feb 28 11:11:32 CST 2008
Hey, we're back to AG1.
On Feb 28, 2008, at 3:17 AM, Andrew Rowley wrote:
> Hi,
> We found that to enable the client to launch external processes,
> you need something in addition to the web browser. We decided to
> use java for this – in both applet and web application forms (an
> applet is used to talk between the web browser and the web start).
> The web start application does all the backend work, and the web
> browser is then used for the gui front end. The communication to
> the web application side (which then communicates to the AGTk
> server) is via AJAX – we have designed an XMLRPC queuing system for
> this. This queue is also used to receive events at the browser gui
> side (such as a user joining the session).
> One of the main issues we came across was coping with the user
> refreshing the page. This is an issue for us because we are
> developing in a portlet environment. Without this, we could have
> just said that the page should never be refreshed I guess.
> Andrew J
> Andrew G D Rowley
> Senior Development Officer
> Research Computing Services
> The University of Manchester
> Kilburn Building, Oxford Road
> Manchester, M13 9PL
> t : +44 (0) 161 275 0685
> e : Andrew.Rowley at manchester.ac.uk
> w : www.manchester.ac.uk/researchcomputing
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On
> Behalf Of Luis Galárraga
> Sent: 27 February 2008 23:09
> To: Thomas D. Uram
> Cc: ag-dev at mcs.anl.gov; alejandro moreno; Alejandro Moreno; Ing.
> Verónica Macías; Marisol Villacrés
> Subject: Re: [AG-DEV] Web client for AG
> Thomas,
> Thanks a lot for your help. I feel there is light at the end of the
> tunnel!!! However, as you can imagine, we have important time
> constraints. A web client is one of our possibilities (my favorite
> one) and looks a hard matter. One important point for us, is
> portability of the client, that is why we considered the web
> approach. Other options are a lightweight client application
> written in Python, an applet or a Java Web Start application . To
> start, we would just implement audio and video transmission, then
> we could extend the application to support all AG functionalities.
> I would like to know your opinion about these options.
> And finally, would you recommend us to use AGTk 3.0? How feasible
> is it considering the available resources until now??. Thanks again!!!
> Regards,
> Luis Galárraga
> 2008/2/27, Thomas D. Uram <turam at mcs.anl.gov>:
> Hi Luis:
> I'm the tech lead at Argonne for the Access Grid project. I'm very
> interested in the work you are proposing, and have some comments:
> - The API documentation has not, as you've noticed, been updated for
> AG3. This needs to be done. I could generate documentation of the
> web
> services interfaces fairly easily, which is necessary since there have
> been some changes from AG2.
> - There are a couple ways to approach a web-based client. One is to
> build an "adapter" between the VenueServer and the web browser; this
> adapter would accept HTTP from the user, make SOAP calls to the AG
> VenueServer, and return HTTP responses to the user. I wrote a basic
> example of this here: http://www.accessgrid.org/node/971 . Another,
> possibly better solution, would be to make the SOAP calls at the
> client
> using a JavaScript SOAP implementation. Both of these leave open the
> question of how to handle the audio and video.
> It's a priority for us to update the documentation, but I can't
> promise
> when that will be done. If we can help answer questions in the
> meantime, please don't hesitate to ask either here on the ag-dev list,
> or by emailing me directly.
> Thanks,
> Tom Uram
> On 2/26/08 3:06 PM, Luis Galárraga wrote:
> > Greetings:
> > I am really interested in Access Grid Development as I take part
> in a
> > small community who is developing a software for videoconferencing
> > based on AGTk. At the moment, we are in the design phase and some of
> > us are analyzing the possibility of writing a web client for Venues.
> > Of course, there are certain constraints: we only need to use AG in
> > the easiest configuration, personal node. We would like to know your
> > opinions about this decision. How difficult and feasible is
> that?. (We
> > have discuss some technical facts and consequences). It is obvious
> > that the advantages of doing that are numerous.
> > Thanks in advance for your contributions to this topic.
> > Regards,
> > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080228/df23bcb4/attachment.htm>
