[AG-DEV] Certificate Management Tool crashes in Ubuntu 7.10
Luis Galárraga
lgalarra at fiec.espol.edu.ec
Mon Feb 25 17:06:27 CST 2008
I have installed AGTk 3.1 in two machines (one with Ubuntu Desktop 7.10 and
the other one Ubuntu Server 7.10 with Xfce) according to the instructions in
http://www.vislab.uq.edu.au/research/accessgrid/software/debian/gutsy.html.
I could successfully run the Venue Client and ask for a user and a service
certificate (for a Venue Server). The certificate arrived two business days
later as pointed in the system, but when I chose Tools > Manage
Certificates, I saw the following debug message (taken from the first
machine. The problem is present in both):
Traceback (most recent call last):
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/wxgui/CertificateManagerWXGUI.py",
> line 176, in <lambda>
> lambda event, win=win, self=self: self.OnShowNew(event, win))
> File
> line 237, in OnShowNew
> self.certificateManager, self)
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/wxgui/CertificateManagerDialog.py",
> line 25, in __init__
> self.identBrowser = IdentityBrowser(self.notebook, -1, self.certMgr)
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/wxgui/IdentityBrowser.py",
> line 57, in __init__
> CertificateBrowserBase.__init__(self, parent, id, certMgr)
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/wxgui/CertificateBrowserBase.py",
> line 27, in __init__
> self.Load()
> File
> line 86, in Load
> data, columnStrings = self._FormatCert(cert)
> File
> line 286, in _FormatCert
> valid = self.certMgr.CheckValidity(cert)
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/CertificateManager.py",
> line 375, in CheckValidity
> if self.VerifyCertificatePath(cert):
> File
> line 405, in VerifyCertificatePath
> issuers = filter(lambda x: not x.IsExpired(), issuers)
> File
> line 405, in <lambda>
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py",
> line 1337, in IsExpired
> return self.cert.IsExpired()
> File
> line 1523, in IsExpired
> return IsExpired(self.cert)
> File
> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Security/Utilities.py",
> line 36, in IsExpired
> before_tuple = time.strptime(str(before_time),format)
> File "/usr/lib/python2.5/_strptime.py", line 330, in strptime
> (data_string, format))
> ValueError: time data did not match format: data=Apr 21 00:52:18 2007
> GMT fmt=%b %d %H:%M:%S %Y %Z
I got the same when running CertificateManagement3.py from console. I would
like to know if it is a non-reported bug in order to report it as soon as
possible. If you know a possible quick solution (consisting maybe in
changing a configuration file, making changes in the code, etc.), I would
thank you expose it.
Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080225/7bdd5426/attachment.htm>
