[AG-DEV] Dev environment
Eric Olson
eolson at mcs.anl.gov
Tue Feb 5 14:22:44 CST 2008
Hi Mike,
If I'm reading this right, you just need to set the variable
"PYTHONPATH". That will affect where "import" looks for files.
Not that you need to, but if you've run tools/CvsSetup.py there will be
an env-init.bat file that can do this for you. Note, it also sets
AGTK_LOCATION, which affects where toolkit resources are found like Node
Services, shared apps, etc.
Eric
Michael Miller wrote:
> I'm trying to run things from source and I'm wondering what I'm doing
> wrong:
> C:\Users\mimiller.NCSA\Documents\UIUC\NCSA\VTS\AG\source\AccessGrid\bin>set
> ALLUSERSPROFILE=C:\ProgramData
> APPDATA=C:\Users\mimiller.NCSA\AppData\Roaming
> CLASSPATH=.;C:\Program Files\Java\jre1.6.0\lib\ext\QTJava.zip
> CommonProgramFiles=C:\Program Files\Common Files
> COMPUTERNAME=LOKI
> ComSpec=C:\Windows\system32\cmd.exe
> FP_NO_HOST_CHECK=NO
> HOMEDRIVE=C:
> HOMEPATH=\Users\mimiller.NCSA
> LOCALAPPDATA=C:\Users\mimiller.NCSA\AppData\Local
> LOGONSERVER=\\BALL-DC1
> NUMBER_OF_PROCESSORS=2
> OS=Windows_NT
> Path=C:\Users\mimiller.NCSA\Documents\UIUC\NCSA\VTS\AG\source\AccessGrid;C:\Pyth
> on24\;C:\Python24\Lib\site-packages\pywin32_system32;C:\Python23\.;C:\Program
> Fi
> les\ActiveState Komodo
> 3.5\;C:\Windows\system32;C:\Windows;C:\Windows\System32\W
> bem;C:\Program Files\Wave Systems Corp\Dell Preboot Manager\Access
> Client\v5\;C:
> \Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program
> Files\MIT\Kerbero
> s\bin;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;C:\Program
> Files\MySQL
> \MySQL Server 5.0\bin;C:\PHP\;C:\Program
> Files\OpenAFS\Client\Program;C:\Program
> Files\OpenAFS\Common;C:\Program Files\QuickTime\QTSystem\;C:\Program
> Files\cvsn
> t;
> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.pyc;.pyo;.pyw;.py
> ;.pys
> PROCESSOR_ARCHITECTURE=x86
> PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
> PROCESSOR_LEVEL=6
> PROCESSOR_REVISION=0f0b
> ProgramData=C:\ProgramData
> PROMPT=$P$G
> PUBLIC=C:\Users\Public
> QTJAVA=C:\Program Files\Java\jre1.6.0\lib\ext\QTJava.zip
> RoxioCentral=C:\Program Files\Common Files\Roxio Shared\9.0\Roxio
> Central33\
> SESSIONNAME=Console
> SystemDrive=C:
> SystemRoot=C:\Windows
> TEMP=C:\Users\MIMILL~1.NCS\AppData\Local\Temp
> TMP=C:\Users\MIMILL~1.NCS\AppData\Local\Temp
> USERDNSDOMAIN=AD.NCSA.EDU
> USERDOMAIN=NCSA
> USERNAME=mimiller
> USERPROFILE=C:\Users\mimiller.NCSA
> windir=C:\Windows
> C:\Users\mimiller.NCSA\Documents\UIUC\NCSA\VTS\AG\source\AccessGrid\bin>c:\pytho
> n24\python.exe VenueServer.py
> Traceback (most recent call last):
> File "VenueServer.py", line 32, in ?
> from AccessGrid.Toolkit import Service, MissingDependencyError
> ImportError: No module named AccessGrid.Toolkit
> You can see from the PATH that I'm trying to make python look at the
> source directory rather than the production install directory. Should I
> be setting the path somewhere else?
> Any suggestions are greatly appreciated.
> Michael
