[AG-DEV] Newbie developer code submission questions
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Apr 15 03:38:35 CDT 2008
Hi Myk,
>I have some tweaks for SharedPresentation finished and tested. I
looked
> over the Developer docs and the submission process for new code is not
> clear. I have subversion installed, but I'm not familiar enough with
it
> to know what to do. Any guidance is greatly appreciated. I'm happy
to
> document my experience for others.
Perhaps do context diff and submit it as a bugzilla attachment.
If you have checked the source code using svn and have the modified file
in place, do a 'svn diff' on the command-line or thru menu in
TortoiseSVN or whatever GUI you might be using.
If you've modified the file directly and have a copy of the original
somewhere (lets say the files are filename.py and filename.py.orig),
issue the following to get a context diff to stdout:
diff -u filename.py.orig filename.py
On Windows you may need cygwin to be installed for the diff utility.
Cheers,
Doug
