[AG-DEV] VenueServer env var
Michael Miller
mimiller at ncsa.uiuc.edu
Tue Nov 6 11:23:41 CST 2007
thanks António, my hosts file was incorrect.
myk
At 11:14 AM 11/6/2007, Antonio Bandeira wrote:
>Hi,
>This may be caused for bad DNS name resolution. You should set the box name
>(FQN) in your DNS server.
>Try setting the /etc/hosts with your (external) IP address for your FQN,
>also make sure "localhost.localdomain" is only pointing to the loopback IP
>address (127.0.0.1).
>Regards,
>António Bandeira
>FEUP :: SICC ~ uTICM
>+351 225 574 199 (ext.3535)
>bandeira at fe.up.pt
>-----Original Message-----
>From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf
>Of Michael Miller
>Sent: terça-feira, 6 de Novembro de 2007 17:05
>To: ag-dev at mcs.anl.gov
>Subject: [AG-DEV] VenueServer env var
>When I start my VenueServer the URL always shows up thus:
>Default Venue Url: https://localhost.localdomain:8000/Venues/default
>What am I forgetting to set?
>Thanx,
>Michael Miller
>System Engineer
>Video Technology Services
>Internal Infrastructure Division
>Administration Directorate
>National Center for Supercomputing Applications
>University of Illinois - UC
>217-649-0747
>"If you're clear in your vision and trust the people in your team
>with clear objectives, they will invariably do their best to achieve
>everything desired, and usually deliver everything you could have
>hoped for and even more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
people in your team with clear objectives, they
everything you could have hoped for and even more." -Paul Debevec
