[AG-DEV] AG3.1 Vic on OSX Issues
Todd Zimmerman
toddz at sfu.ca
Fri Jul 27 15:22:15 CDT 2007
Todd Zimmerman wrote:
> Wondering if anyone else is experiencing problems with the OSX vic build for AG3.1. On our setup, we
> have a OSX box doing the video consuming - and a linux box doing the vid capture. The linux box can
> see all of the incoming (muted) sources, however the OSX box shows no incoming video at all.
> I've tcpdumped on both the bridge machine and the local OSX box and there are definitely incoming
> packets from the bridge; however vic shows no video. The fact that there are packets arriving seems
> to rule out firewall - so I'm left with vic as the problem.
> I've tried using vic as a VideoService on the OSX box and sending out via iSight camera also. Vic
> does show the iSight - but still no incoming video. I have got the video feeds to appear once;
> however I can't replicate it. I believe it started in some combination of starting a second vic
> from the command line and sending a feed out to the bridge... but like I said, I can't replicate it.
> I'll file a bug report but wanted to make sure it wasn't a local issue first.
BTW, PowerPC on a G5 (for clarification).
Cheers,
Todd
