[AG-DEV] Additional Grabber settings
Jason Bell
j.bell at cqu.edu.au
Sun Jul 1 18:14:59 CDT 2007
G'day Doug, Todd and all
To support Todd's comments, I have to adjust my "Gamma and Gain" levels
each time I switch Venues or simply start the Venue Client.
Generally my camera "feed" is quite dark initially. I simply hit the
reset button which resets everything and then I adjust the Gamma and
Gain settings to my liking.
Currently, I only have to do this on one machine that has a USB camera
attached.
Don't get me wrong, once everything is set, it works fine! It simply
would be nice to be able to hard "set" these variables somehow.
Jason.
-----Original Message-----
From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
Sent: Saturday, 30 June 2007 10:05 AM
To: AG-DEV
Subject: Re: [AG-DEV] Additional Grabber settings
On Fri, 2007-06-29 at 10:48 -0700, Todd Zimmerman wrote:
> Jason Bell wrote:
> > G'day All
> > I don't know if there is an equivalent under windows or whatever,
but I
> > notice with V4L2, there are some additional grabber controls, these
> > being Gamma and Gain.
> > What is the chance of making these potentially a savable
configuration
> > item???
> > As I find I have to adjust my USB camera setting each time when vic
> > starts. Does vic have a default file like rat has???? Or should I
> > create a vic.tcl file to configure these settings????
> Here, here! After using the new Vic for the last few weeks - and
having to set this every time I
> change venues... I could _really_ use a way to set this automatically.
Your webcam driver kernel module should be remembering it's settings
till a reboot or it's rmmoded. Which driver you using? You could
probably also set your preferred values in /etc/modprobe.conf.
For some webcams like the UVC ones, you need to set the 50Hz flicker
prevention or 60Hz flicker prevention which needs to be set outside of
vic. Unfortunately the flicker prevention control is a private control
specific to the UVC webcam driver, so can't just be added as a generic
V4L2 control.
Cheers,
Doug
