[AG-DEV] Problem of running ‘r_3_0_2_final’ source code downloaded from CVS.
박종민
alrogi at icu.ac.kr
Wed Jan 17 01:41:35 CST 2007
Hello. I worked to modify Access Grid 3.0.2 Toolkit.
However, I cannot run ‘r_3_0_2_final’ source code downloaded from CVS.
Although I performed the method of ‘README-developers’ file in folders
downloaded from CVS,
I cannot run Access Grid 3.0.2 source code.
I installed .NET 2003 for ‘devenv.exe’. And then I use Windows XP
platform.
I ran command as follows.
E:\AGTk>python AccessGrid/tools/CvsSetup.py --agdir AccessGrid
Error message is like this.
Creating file E:\AGTk\AccessGrid\Config\nodeConfig\defaultWindows from Acces
sGrid\packaging\config\defaultWindows
Generating Interfaces
C:\Python23\python.exe: can't open file 'C:\Python23\Scripts\wsdl2py.py'
'C:\Python23\Scripts\wsdl2dispatch.py'
To use this configuration:
Make sure media-related programs (vic, rat, etc.) are in your path.
On Windows: copying the vic and rat related binaries (if needed,
from a real install) into their own directory before adding them
to your path is recommended. If you don't want to bother
modifying
your path, copying them into AccessGrid/bin is a quick fix.
set AGTK_LOCATION to E:\AGTk\AccessGrid
set PYTHONPATH to E:\AGTk\AccessGrid
Wrote win32 batchfile init to env-init.bat
E:\AGTk>
To solve this error, I tried to install ‘SOAPpy-0.12.0’. However, the
error also is presented.
E:\AGTk\SOAPpy-0.12.0>python setup.py install
Traceback (most recent call last):
File "setup.py", line 8, in ?
from SOAPpy.version import __version__
File "E:\AGTk\SOAPpy-0.12.0\SOAPpy\__init__.py", line 5, in ?
from Client import *
File "E:\AGTk\SOAPpy-0.12.0\SOAPpy\Client.py", line 57, in ?
from Parser import parseSOAPRPC
File "E:\AGTk\SOAPpy-0.12.0\SOAPpy\Parser.py", line 8, in ?
import fpconst
ImportError: No module named fpconst
I think that this is because ‘fpconst.zip’ is not installed.
In AccessGrid.org homepage (http://www-
unix.mcs.anl.gov/fl/research/accessgrid/software/developer.html),
Because the hyperlink of ‘fpconst.zip’ is not operated, I cannot download
this file.
In conclusion, I want to run ‘r_3_0_2_final’ source code downloaded from
CVS.
If anyone who knows to solve this situation exists, please send email to
me.
Thank you for your reading.
Jongmin Park
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20070117/bdec0ea2/attachment.htm>
