[AG-DEV] OSX SharedApp Pythonw
Todd Zimmerman
toddz at sfu.ca
Fri Sep 29 10:52:19 CDT 2006
Ah... excellent!
Thanks for the help Eric/Tom.
I think this is the case, but does opening a .agpkg (AGTk2) or .agpkg3 (AGTk3) file from the data
store automatically update/install the package properly? I assume it does, but wanted to make sure
this was true for all platforms/agversions.
Thanks for your help.
Todd
Thomas D. Uram wrote:
> Also, there was a fix made in 3.0.2 to force the use of /usr/bin/pythonw
> on OSX.
> Are you using 3.0.1?
> Tom
> On 9/28/06 4:00 PM, Eric Olson wrote:
>> Hi Todd,
>> The python location comes from when the app is registered using agpm.py.
>> So reregistering with: pythonw agpm.py ....
>> Should fix it for you.
>> Eric
>> Todd Zimmerman wrote:
>>> Having a slight issue with AG3 and my SharedDesktop app.
>>> Looking at the VenueClient.log, it looks like its launching with
>>> /usr/bin/python
>>> When I try to run the logged line straight from the commandline, I
>>> get the 'you must run this
>>> program with pythonw' error msg.
>>> Is there a way to properly define this in the .app file?? I don't
>>> have any other AG3 sharedapps on
>>> OSX to compare to...
>>> Thanks,
>>> Todd
