[AG-DEV] Parallelize some of the functions of the Start-Up for the Venue Client
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Mon Sep 11 03:48:50 CDT 2006
Another idea is to allow your bridge to associate with more than one registry. This would allow me to make my bridge available to other venue servers if I wanted to.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Brian Corrie [mailto:bcorrie at sfu.ca]
> Sent: 08 September 2006 23:54
> To: Andrew.Rowley at manchester.ac.uk
> Cc: Thomas D. Uram; Jason Bell; ag-dev at mcs.anl.gov
> Subject: Re: [AG-DEV] Parallelize some of the functions of the Start-Up
> Hi all,
> I like this idea as well - associating a registry with a venue server
> seems to make the most sense to me. Then when one goes to the Argonne
> venue server, they use the Argonne associated bridges, but when they use
> the WestGrid server they get our registry. This makes life much easier
> for the end users as they don't have to change their settings, the venue
> server knows where the registry is...
> Gets my vote!
> Brian
> Andrew A Rowley wrote:
> > Hi,
> > One thought I had would be to have the server give the client the
> registry url. This would allow people who usually use one venue server to
> use a different venue server, including the associated bridges, without
> having to change their settings.
> > Currently, if I decide to put our bridge on our own separate registry,
> and someone that usually uses the vv3 server wants to use our server, they
> would have to manually go in and specify the new bridge registry so that
> they could use our bridge (either through a new UI interface, or through
> editing the file). This adds an extra complication to the process.
> > Andrew :)
> > RSS Group,
> > Kilburn Building,
> > Oxford Road,
> > Manchester,
> > M13 9PL,
> > UK
> >> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On
> Behalf
> >> Of Thomas D. Uram
> >> Sent: 07 September 2006 23:35
> >> To: Jason Bell
> >> Cc: ag-dev at mcs.anl.gov
> >> I'll clarify and suggest some things. Feel free to comment or suggest
> >> alternatives.
> >> The base problem is well understood: The single universal bridge
> network
> >> can be joined by anyone, including people whose bridge machines are
> behind
> >> a firewall. Before 3.0.2, VenueClients pinged bridge machines and had
> a
> >> set timeout of one second, so even if this problem had occurred before,
> it
> >> was not noticeable (no one reported it, anyway). As of 3.0.2, 'ping'
> has
> >> been swapped out for an RPC call to the bridge, and the timeout was
> >> inadvertently not carried over. I've put together a modified
> >> RegistryClient.py
> >> that includes a one-second timeout; interested people can look here:
> >> http://www.mcs.anl.gov/~turam/ag3/registry/RegistryClient.py
> >> This fix should potentially be rolled out right away to overcome the
> >> problem with bridges behind firewalls. I'd be interested to know if
> >> people
> >> verify this fix, so we can move ahead with it.
> >> We shouldn't have to worry about the list of bridges growing to an
> >> unscalable number: VenueClients request a max of 10 bridges
> >> from the registry. This imposes a number of limitations, several of
> >> which we'll address in the coming development.
> >> Having clients time out is essential. It has always been our plan to
> have
> >> the bridge network supported in more of a p2p style than the current
> >> registry. This would remove the single point of failure that is now
> the
> >> registry. With this p2p model, there would be no central registry to
> >> determine whether
> >> a bridge is suitable (i.e., not behind a firewall), so allowing clients
> to
> >> quickly measure connectivity to a bridge and be able to timeout is
> >> required.
> >> There's a fair amount of interesting work related to p2p here; if
> someone
> >> is knowledgeable and interested, let us know.
> >> It has also been our plan to let people run alternate bridge networks,
> >> and configure venue clients to use that alternate bridge network.
> >> Eventually it might make sense for them to also be able to use multiple
> >> bridge networks (e.g., the overarching AG bridge network, plus the
> >> private bridge network established within their institution).
> >> I'll try to get our plans written up and sent to the list in the near
> >> future,
> >> so they're open for comment before and during implementation.
> >> Tom
> >> On 9/5/06 9:07 AM, Jason Bell wrote:
> >>> G'day all
> >>> I think I should mention that while testing my own AG 3 Bridge, I was
> >>> one of those "baddies" as well.
> >>> What this highlighted is how easily it would be for someone to
> "simply"
> >>> create a "baddy" bridge without realising it.
> >>> The purpose for my testing was to add additional documentation on my
> >>> install guide on how to configure a unicast bridge and Venue Server
> for
> >>> AG 3. I am very reluctant to release any documentation that shows how
> >>> to configure a Bridge as it may inadvertently create more "baddies",
> >>> thus causing the AG3 VenueClient to be almost unusable due to the long
> >>> start-up time.
> >>> Anyway, some constructive comments in my opinion on ways we could
> >>> possibly improve this would be:
> >>> * Having the Load_Bridge() run/execute as a separate
> >>> process/thread in which would operate independent of the starting up
> of
> >>> the VenueClient itself. The benefits of this could be:
> >>> - Running as a separate process shouldn't affect the
> >>> performance of starting the Venue Client, etc.
> >>> - Also, you could re-run this function separately which
> >>> would continually update the latest list of bridges. As I have found
> >>> recently that the list of bridges is only as accurate to when the
> >>> VenueClient was first started.
> >>> * Another idea, based upon Rhys's suggestion is that if something
> >>> doesn't respond after a short delay (rather than a time out), then
> don't
> >>> list the bridge. This would then only list bridges that would be
> >>> acceptable to use. The downside of this is that the list of bridges
> >>> "WILL" grow and still cause some delay, though not as long.
> >>> * Based upon Andrew's suggestion, having the ability for a Bridge
> >>> to Register to different registries, would allow (I think) the bridges
> >>> to be assigned to various regions. That way, a registry could list
> >>> "Good" unicast bridges for the various regions, cutting down the
> number
> >>> of bridges tested and loaded.
> >>> I honestly think that the possible solution to this problem is most
> >>> likely a combination of some of the suggestions above, and possibly
> some
> >>> other ideas.
> >>> Anyway, I think this is a very important issue and hopefully we may be
> >>> able to come up with some real "fixes" to the problem.
> >>> Cheers,
> >>> Jason.
> >>> From: Christoph Willing [mailto:willing at vislab.uq.edu.au]
> >>> Sent: Tuesday, 5 September 2006 4:54 PM
> >>> To: Rhys Hawkins
> >>> Cc: Jason Bell; ag-dev at mcs.anl.gov
> Up
> >>> On 04/09/2006, at 3:45 PM, Rhys Hawkins wrote:
> >>> [snip]
> >>>> I've commented out line 125 in AccessGrid/Registry/
> >>>> RegistryClient.py, ie:
> >>>> #self.bridges = self._sortBridges(maxToReturn)
> >>>> I don't know whether this will help your colleague or not. It
> >>>> certainly
> >>>> makes things quicker for me. If you're just testing a local bridge
> >>>> then
> >>>> you could just stick you local bridge description in the beginning
> >>>> of the
> >>>> list to fake the sort. Although this is just hacking for testing
> >>>> purposes
> >>>> and doesn't solve the actual problem.
> >>> I was doing something similar (VenueClient.py at line 199, comment
> >>> out self.__LoadBridges()), which is fine if you don't need bridges.
> >>> Today I needed to connect to a site whose only visibility was through
> >>> a bridge they were running, so I had to reinstate them, but block the
> >>> baddies. I now have a list of offending bridges inserted at the
> >>> beginning of the PingBridgeService() definition (line 63) in
> >>> RegistryClient.py. These sites are skipped as follows:
> >>> def PingBridgeService(self, bridgeProxy):
> >>> banned = ['some.site', 'another.site']
> >>> for b in banned:
> >>> if bridgeProxy._ServerProxy__host.startswith(b):
> >>> return -1
> >>> self.log.info('PingBridgeService: trying %s' %
> >>> bridgeProxy._ServerProxy__host)
> >>> etc. as before
> >>> The extra logging line shows progress through the bridges a bit
> >>> better and identifies new baddies.
> >>> Of course its cumbersome to edit RegistryClient.py everytime a new
> >>> baddy is detected (there have been a few recently), but I generally
> >>> have a fast start up now, as well as having access to "good" bridges.
> >>> Maybe a separate configuration file containing the baddies would be
> >>> better; the VenueClient could consult it at startup before processing
> >>> the bridge list.
> >>> chris
> >>> Christoph Willing +61 7 3365 8350
> >>> QCiF/QPSF Access Grid Manager
> >>> University of Queensland
