[AG-DEV] CVS tags
    Eric Olson
    eolson at mcs.anl.gov
    Thu Jun 29 12:18:29 CDT 2006
Hi Doug,
You used the word "unfortunately", so I'll just clarify in case this
minor point isn't clear:  r_2_branch and r_2_3_final are both
temporarily referring to the 2.x branch (using an alias) to give people
time to stop using r_2_3_final.  So your recent checkin with the old tag
worked fine (which you may have noticed).
Eric
Douglas Kosovic wrote:
> Hi Tom,
>> We added CVS tags yesterday for a number of releases.  Detail of the tags
>> is available online at:
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/cvs.html
>> Yesterday's changes include:
>> - A new r_2 tag
>> This is a branch tag that refers to the AG2 branch.  It should be used
>> for retrieving code from that branch.
> As there is no 'r_2' tag, I think you meant the 'r_2_branch' tag in both
> this email and the above website.
>> Note:  The r_2_3_final tag incorrectly refers to the AG2 branch
>> instead of the AG2.3 code.  With the introduction of the r_2 tag for
>> the AG2 branch, r_2_3_final can be redirected, and eventually will
>> be.  We do not, however, want to inconvenience anyone relying on that
>> tag.  If you are using the r_2_3_final tag, migrate away from it; if
>> you have questions about doing this, we can help.
> I've now migrated from 'r_2_3_final' to 'r_2_branch', unfortunately that
> was after I checked in the following file:
>   AccessGrid/sharedapps/SharedPresentation/ImpressViewer.py
> and I see what you mean by the r_2_3_final tag incorrectly referring to
> the AG2 branch.
> Cheers,
> Doug
