[AG-DEV] Continuing AG3 Bridge Issues
Todd Zimmerman
toddz at sfu.ca
Thu Jun 22 19:15:34 CDT 2006
Any progress on this? It's fairly frustrating - and makes the WestGrid bridge completely useless.
I hate to really push our user base into upgrading when I'm still seeing issues like this.
However, it doesn't appear that this is the case with (for example) the Argonne bridge - should I
upgrade to CVS Bridge.py?
The behaviour is that, clients requesting the WestGrid bridge from within a venue will receive the
same ip/port info; however, there is no QuickBridge process running for those ports.
Thoughts?
Todd
Todd Zimmerman wrote:
> Not much to show.... but I've attached the Bridge.log file from today.
> Could this be a firewall problem? I haven't seen anything in the firewall logs.. but the only tcp
> port I am explicitly opening for the bridge is tcp 20000.
> Todd
> Thomas D. Uram wrote:
>> The entries regarding 'unexpected processes' should be okay. They're
>> just reporting
>> the death of processes started outside of the reporting context. This
>> could be cleaned
>> up, but has been left in for now as a debugging measure.
>> The bit about 'no bridge registry peers reachable' concerns me; could
>> you send your
>> logfile for me to look at?
>> Thanks,
>> Tom
>>> I continue to have bridge issues with the AG3 bridging software and
>>> was wondering if it was only me
>>> that was experiencing these issues.
>>> The issues are mostly concerning no QuickBridge process being started
>>> (even though the clients are
>>> connecting to the bridge machine).
>>> My Bridge.log file is filled with alternating entries concerning
>>> sigchild's for unexpected process
>>> PID's, and No Bridge registry peers reachable.
>>> Anyone else experiencing this? Should I be trying to run the cvs
>>> version of Bridge.py?
>>> Todd
>> 06/06/06 03:07:44 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.183.102 50824
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 50500
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.183.102 50824 127
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 50500
>> 06/06/06 03:07:44 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.183.102', '-m', '50824', '-u', '50500', '-i', '600']
>> 06/06/06 03:07:46 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.160.60 63088
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51670
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.160.60 63088 127
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 51670
>> 06/06/06 03:07:46 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.160.60', '-m', '63088', '-u', '51670', '-i', '600']
>> 06/06/06 03:07:47 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.163.1 50702
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51786
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.163.1 50702 127
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 51786
>> 06/06/06 03:07:47 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.163.1', '-m', '50702', '-u', '51786', '-i', '600']
>> 06/06/06 03:07:51 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.221.45 56394
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 50294
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.221.45 56394 127
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 50294
>> 06/06/06 03:07:51 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.221.45', '-m', '56394', '-u', '50294', '-i', '600']
>> 06/06/06 03:07:52 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.196.39 57662
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51680
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.196.39 57662 127
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 51680
>> 06/06/06 03:07:52 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.196.39', '-m', '57662', '-u', '51680', '-i', '600']
>> 06/06/06 03:08:54 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27513
>> 06/06/06 03:08:54 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 03:12:10 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27528
>> 06/06/06 03:12:10 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 03:15:27 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27543
>> 06/06/06 03:15:27 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 03:18:43 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27558
>> 06/06/06 03:18:43 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 03:18:51 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27507
>> 06/06/06 03:18:52 -1209051456 Toolkit BridgeFactory.py:168 INFO Removing bridge following death of bridge process (224.2.196.39/57662)
>> 06/06/06 09:23:59 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 233.59.192.2 60502
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51354
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:121 INFO - using existing bridge
>> 06/06/06 09:23:59 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 233.59.192.2 60500
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51852
>> 06/06/06 09:23:59 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 233.59.192.42 56232
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 50322
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 233.59.192.42 56232 127
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 50322
>> 06/06/06 09:23:59 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '233.59.192.42', '-m', '56232', '-u', '50322', '-i', '600']
>> 06/06/06 09:25:36 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27503
>> 06/06/06 09:27:19 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27504
>> 06/06/06 09:28:57 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=27505
>> 06/06/06 09:32:16 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30255
>> 06/06/06 09:32:16 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:33:54 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30266
>> 06/06/06 09:33:54 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:37:11 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30286
>> 06/06/06 09:37:11 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:40:27 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30306
>> 06/06/06 09:40:27 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:43:43 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30327
>> 06/06/06 09:43:43 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:45:22 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30362
>> 06/06/06 09:45:22 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:47:00 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30373
>> 06/06/06 09:47:00 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:50:16 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30417
>> 06/06/06 09:50:16 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:51:54 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30427
>> 06/06/06 09:51:54 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:53:33 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30437
>> 06/06/06 09:53:33 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:55:11 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30448
>> 06/06/06 09:55:11 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 09:58:27 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30468
>> 06/06/06 09:58:27 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:01:44 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30490
>> 06/06/06 10:01:44 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:03:22 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30500
>> 06/06/06 10:03:22 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:05:00 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30511
>> 06/06/06 10:05:00 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:06:38 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30521
>> 06/06/06 10:06:38 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:08:16 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30532
>> 06/06/06 10:08:16 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:09:54 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30543
>> 06/06/06 10:09:54 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:13:11 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30563
>> 06/06/06 10:13:11 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:16:27 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30583
>> 06/06/06 10:16:27 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:18:05 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30593
>> 06/06/06 10:18:05 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:19:44 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30603
>> 06/06/06 10:19:44 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:22:07 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 233.33.100.16 57006
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51700
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 233.33.100.16 57006 127
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 51700
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '233.33.100.16', '-m', '57006', '-u', '51700', '-i', '600']
>> 06/06/06 10:22:07 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 233.33.100.16 57004
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 50328
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 233.33.100.16 57004 127
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 50328
>> 06/06/06 10:22:07 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '233.33.100.16', '-m', '57004', '-u', '50328', '-i', '600']
>> 06/06/06 10:22:08 -1209051456 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.195.27 63142
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:114 INFO Allocated port = 51928
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:131 INFO - creating new bridge
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:41 INFO Starting bridge:
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.195.27 63142 127
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = venueserver2.westgrid.ca 51928
>> 06/06/06 10:22:08 -1209051456 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.195.27', '-m', '63142', '-u', '51928', '-i', '600']
>> 06/06/06 10:23:01 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30621
>> 06/06/06 10:23:01 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:24:39 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30629
>> 06/06/06 10:24:39 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:26:17 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30636
>> 06/06/06 10:26:17 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:27:55 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30644
>> 06/06/06 10:27:55 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:31:12 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30659
>> 06/06/06 10:31:12 -1209051456 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
>> 06/06/06 10:31:41 -1209051456 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=30203
>> 06/06/06 10:33:08 -1209051456 Toolkit BridgeFactory.py:168 INFO Removing bridge following death of bridge process (224.2.195.27/63142)
