[AG-DEV] Shared App migration to 3.0
Roshini Dominic
r2domini at ryerson.ca
Tue Jun 13 13:05:07 CDT 2006
Hi Tom,
I've rearranged my code, quite bit, and tried to see what the problem was and I've narrowed down the error to this:
ftplib.error_perm: 530 Connection rejected.
This is some of the stuff that came up in the Log File, where I think the problem is:
/13/06 11:19:51 2680 DataStore datastore.py:784 INFO DownloadFile: url ftps://vv3.mcs.anl.gov:8006/000001009b54ba42008c00dd0009000818e/r.rd file c:\docume~1\r2domini\locals~1\temp\tmpodf21urd
06/13/06 11:19:51 2680 FTPSClient ftpsclient.py:38 DEBUG Entered FTPSDownloadFile: url=ftps://vv3.mcs.anl.gov:8006/000001009b54ba42008c00dd0009000818e/r.rd destination=c:\docume~1\r2domini\locals~1\temp\tmpodf21urd
06/13/06 11:19:51 2680 FTPSClient ftpsclient.py:101 ERROR Error in FTPSDownloadFile
Traceback (most recent call last):
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\FTPSClient.py", line 82, in FTPSDownloadFile
f.login(user,passw)
File "C:\Python23\lib\ftplib.py", line 362, in login
if resp[0] == '3': resp = self.sendcmd('PASS ' + passwd)
File "C:\Python23\lib\ftplib.py", line 241, in sendcmd
return self.getresp()
File "C:\Python23\lib\ftplib.py", line 214, in getresp
raise error_perm, resp
Cheers
~Roshini
----- Original Message -----
Date: Monday, June 12, 2006 2:16 pm
Subject: Re: [AG-DEV] Shared App migration to 3.0
> Hello Roshini:
> Can you describe in more detail the problem you're having? If you
> get an
> exception, post the entire exception.
> Thanks,
> Tom
> On 6/9/06 12:40 PM, Roshini Dominic wrote:
> > Hi,
> > I've been playing around with Shared Apps, and at the present
> I'm trying to take the Application I made for AG 2.4 and migrate
> it to 3.0. I already read up on the power point presentation and
> the migration instructions. However I'm still encountering a lot
> of errors.(Mainly with the DataStoreClient):
> > 1.) Is there any shared apps that have already been created that
> uses the functionality of DataStore/DataStoreClient? I have
> already looked thru the Shared Presentation & Shared PDF application.
> > 2.)I am having trouble 'opening' data from a file in the venue,
> and viewing it on my Shared App. Also for example: trying to
> 'save' a file through my application into the Data within the
> Venue.
> > Most of the problem seems to be related to the Methods within
> DataStoreClient>
> > LoadData()
> > GetFileData()
> > Is there something in specific that I should look out for?
> > Thanks,
> > Roshini Dominic
