[AG-DEV] Venue Server certificates problem
Rod Harris
rod.harris at anu.edu.au
Tue Jul 11 22:40:29 CDT 2006
Hi All
I'm in the middle of trying to get VB running as a shared app with AG3.
VB is a Java app and I'm using WSIF to connect to the Venue to get the
streams.
I've generated the Java code from the WSDL thats part of AG 3.0.1
I get this error however when calling the GetStreams method:
PKIX path building failed:
sun.security.provider.certpath.SunCertPathBuilderException: unable to
find valid certification path to requested target
After searching today I found a few explanations that reckon that its
that the certificate(s) obtained from the VenueServer are not trusted.
I tried a few hacks to get around this (disabling or modifying
TrustManagers) but nothing worked.
I've used WSIF to successfully connect to another server that doesn't
use SSL so I'm sure the problem is somewhere with the certificates.
I've also tried to connect to both the APAG and ANL venue servers and
had the same problem.
So, I was wondering if anyone has used WSIF to connect to a secure AG3
venue and if so what they did to get it to work.
Cheers, Rod
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.10/385 - Release Date: 11/07/2006
